Old 11-03-2013, 01:14 PM   #11
magnumv8
Default Re: Newb here - '96 Ram pickup?
I would stay with the 360 for two reasons...first the more cubes to get it moving the better, second and the bigger reason the 318 piston is a true flat-top (no valve reliefs) so the restricted cam duration is a big issue with the legal lift spec and that they also run the same diameter intake valve.....
D L Rambo......STK1300
magnumv8 is offline   Reply With Quote
Old 11-03-2013, 03:34 PM   #12
drag55
Check out Ad #181958984 on racingjunk.com Thanks Ron
drag55 is offline   Reply With Quote
Old 11-03-2013, 05:06 PM   #13
James Henry
I agree with the more cubes moving the truck at 3700 lbs. It also seems to me that 48 more cubic inches but the same intake, heads and cam has a factor advantage since there is only 18 hp difference. I didn't know that about the 318. Is one head number better than the other? I have seen some flow figures on the internet, but only for the 466 head. What works for a fuel management system on these?
James Henry is offline   Reply With Quote
Old 11-04-2013, 07:28 PM   #14
magnumv8
The stock iron heads are prone to cracking so NHRA allowed the
Magnum R/T iron head as a legal replacement with a 5 hp penalty...the R/T head was discontinued so at that point NHRA approved the Edelbrock
# 61767 for use instead....If money is no issue obviously the Edelbrock head is the way to go, but if it is I would try and find someone who is doing the conversion to the Edelbrock heads who has the R/T heads already and see if they would be willing to make you a deal on them.....
Also any of the approved fuel injection computers will run it......
D L Rambo.......Stk 1300
