Old 11-09-2013, 06:03 PM   #1
ruthlessracing
Default Ford,cam,rockers,heads,pistons,lifters
New comp cams solid roller. Specs are 238/248@.050. 588/588.114ls $220 shipped
New probe 4.125 forged flattop pistons and pins. Part #14427std. The pistons have 1.115 comp height and .927 pin. $400 shipped
Used Holley upper n lower Intake with 65mm throttle body. part # hly-300-72s $500 shipped
NEW COMP CAM SOLID ROLLER CAM FW , HAS 55MM CAM BEARING ON THE FIRST FOUR JOURNAL AND A 50MM REAR CAM BEARING, , LIFT IS ..768 INTAKE AND .707 WITH A 1.6 ROCKER, EXHAUST, DURATION AT .050 IS 287 / 300 DEGREES, LOBE SEPERATION IS 114 $325
USED COMP CAMS 55MM .726 INTAKE AND .693 WITH A 1.65 ROCKER, EXHAUST, DURATION AT .050 IS 250 / 272DEGREES, LOBE SEPERATION IS 112 DEGREES, $250 SHIPPED
USED COMP CAMS LIFT IS .704INTAKE AND .672 WITH A 1.6 ROCKER, EXHAUST, DURATION AT .050 IS 254 / 272 DEGREES, LOBE SEPERATION IS 112 DEGREES $250 SHIPPED
Used crower 15510 hyd roller cam.it is good condition $225 shipped
USED COMP CAMS SOLID ROLLER CAM, SPECS ARE 252/256, 702/672/.115L. CAM IS IN GOOD CONDITION $200 SHIPPED
USED COMP CAMS SB FORD SOLID ROLLER CAM, SPECS ARE 251/264 AT .050,680/672 LIFT WITH 113LS. THE CAM IS IN GOOD CONDITION. $200 shipped
USED CROWER HIPO SOLID ROLLER LIFTERS $325 SHIPPED
USED FORD RACING BLUE 1.72x3/8" WITH LOCKES, THE ROCKERS ARE IN GOOD CONDITION $190 SHIPPED
Used comp cams solid roller lifters. All roller are tight and roller good. They have about 75 runs $225 shipped
used howard solid roller lifters $200 shipped
new howard solid roller lifters $285 shipped
ruthlessracing is offline   Reply With Quote
Search this Thread:
Advanced Search
