Old 11-11-2013, 09:22 PM   #11
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Default Re: Better Rear Brakes?
I was also told that switching the brake lines on the master from the factory setting is better (holds more pressure on the rear wheels) BUT I have never tried it and don't know anyone personally so this could be one of those old bench racing stories. Has anyone else tried this?
Thanks
Kevin
Old 11-11-2013, 09:22 PM   #12
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
My 70 Nova held better on the starting line after we swapped the factory disc brakes for drums plus the drums were lighter. It's possible that there was a problem with the discs, but drums in the front worked better to stage. If I remember right, we picked up about 500 rpm over the discs.
Ron Gusack is offline   Reply With Quote
Old 11-12-2013, 10:03 AM   #13
SSDiv6
In addition to re-arching the shoes and putting larger wheel cylinders, try to find a brake relining shop and ask them if they would put the same lining material used on forklift brakes. The coefficiency of friction of the forklift brake lining is higher.
Old 11-12-2013, 10:07 AM   #14
Liked 10,835 Times in 2,252 Posts
Don't forget to check the rear drums for cracks every time you swap sides with the slicks, also its a good time to adjust the breaks. We could hold the cuda at 3200 rpm with 10 inch stock drums, of course changing the backing plates every year was required due to stretching the mounting holes.
Old 11-12-2013, 10:24 AM   #15
Jim Cimarolli
Liked 166 Times in 46 Posts
Thumbs up Re: Better Rear Brakes?
X2, the front drum brakes will fix your problem.
Jim Cimarolli is offline   Reply With Quote
Old 11-12-2013, 10:30 AM   #16
R. Thorne
Liked 101 Times in 34 Posts
Used to arc brake shoes many years ago. Essentially it matches the arc of the shoe to the arc of the drum. If you can't find anyplace to do it ( check for HD truck shops), good used shoes would be an option (they have worn to fit the drums). Also, your brake drums may have been turned too much, check them against std diameter.
R. Thorne is offline   Reply With Quote
