Old 11-09-2013, 03:09 PM   #21
larrylomascolo
Liked 66 Times in 29 Posts
Default Re: .031 dykes
So,to say i have a set of pistons cut for .031 dykes ,tight fit 4.30 bore,do they make this type of ring any more or am i s.o.l..this was the way to go back then,
Old 11-09-2013, 04:26 PM   #22
Liked 1,893 Times in 423 Posts
Speed Pro has the Dykes rings in their current catalog.
Be aware that the guys at Speed Pro are telling me that some of the tooling is very old, and if it is not being used to make "A movers", it may not be replaced.
For example, much of the tooling used to make my beloved SS-50U oil rings is old, and probably will not be replaced. I like the SS-50U because it uses a standard width and thickness rail, and the tension is set by the expander, making it a ring that is very easy to install, is very consistent, and very easy to adjust the tension. I do not like the "Hastings" or "Perfect Circle" gold style oil ring, they set the tension with the rails. I do not find them as consistent, and with the ultra low tension sets, they are much harder to install, and more likely to screw up and cause a problem for a customer who does not build a lot of engines. Those oil rings are the only ones I see popping out of expanders, getting folded, and screwing up the ring, the bore, and the piston. Never had a customer do that with a Speed Pro.
Total Seal will make about anything you will pay for.
Old 11-10-2013, 12:45 PM   #23
CFMCNC
Posting from home ,Have some old inventory at the shop will check tomorrow .Bill C.
CFMCNC is offline   Reply With Quote
Old 11-10-2013, 09:29 PM   #24
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
thanks Bill.
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 11-10-2013, 09:40 PM   #25
Ed McLawhorn Jr.
Originally Posted by JRyan View Post
Ed Jr.,
Don't worry about the .031 Dykes ring being a a worthy piece for your 283. Ours Olds would still run in the 10's at 120 mph (on kill) in SS/NA after 275 runs on the Dykes rings.
Oh! They were a special set made by Gregg Luneak and were 5/64 " rings rather than the common 1/16 " rings because nobody makes a 3.865 Moly 1/16" ring anymore. All that was available at the time were the 5/64" rings. They weren't supposed to work, but obviously they do.
Jerry
Jerry, thanks....I'm not too worried about the dykes....they have proved themselves to make decent power. It's just harder to find stuff for them in a world where companies market to sell their latest and greatest.
Do you have a contact # for Gregg?
Ed
Old 11-12-2013, 09:51 AM   #26
Liked 10,838 Times in 2,253 Posts
Gregg 760-630-9094
Old 11-12-2013, 02:06 PM   #27
CFMCNC
Originally Posted by Ed McLawhorn Jr. View Post
thanks Bill.
Ed
Ed ,do not have .031 in 3.935 size But for some one we have.031Speed Pro #R9941.025,4.025 and R10177.035.4.285 .Also have R9785 .035 and .065, 3.905 and 3.935.043 1/16 3/16.Bill C.
Old 11-13-2013, 04:41 PM   #28
randy wilson
Liked 22 Times in 22 Posts
Just have Rebco cut them to 0.043, and match depth. It ain't that expensive.
don,t have one
Old 11-13-2013, 04:43 PM   #29
randy wilson
When in dire straits, have had a 1\16th milled down to exact depth.
don,t have one
Old 11-13-2013, 08:03 PM   #30
Ed McLawhorn Jr.
Called Gregg and he can provide the 3.940 dykes. It's good to know where I can get another set when needed. thanks to everyone for adding to the post....it's what makes this site so valuable for classracers.
Ed
