Old 11-17-2013, 01:34 PM   #1
Robert Swartz
Robert Swartz's Avatar
Default Ford Carb size per Classification Guide
1978 Ford. Trying to clarify here. Looking at the Nhra blueprint guide. For the carb size it's listed as:
Carb Sizes - 1260 x 1420/1023 x 1064
My question, what number do you use? Is this two seperate numbers for different carbs? Do both these sets of numbers come into play somehow? Forgive my ignorance, just trying to interpret the information.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 11-17-2013, 01:46 PM   #2
jmantle
Liked 172 Times in 81 Posts
Default Re: Ford Carb size per Classification Guide
My understanding is it refers to the primary and secondary venturi and throttle bore measurements.
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 11-17-2013, 02:59 PM   #3
Joe Toller
Liked 9 Times in 9 Posts
That looks as if it's under the 2.3, the Holley/Weber carb. the 302 shows a Ford carb. You may have to refer to your tech director, but the 302 should be the 1.08 venturi Autolite? That's what came off my 78-vintage motor. I have a 79-vintage D9DE which is also, a 1.08 venturi Autolite.
