Old 11-17-2013, 03:11 PM   #11
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Default Re: Aluminum rads in stock
Try and even find a copper-brass rad for some applications?NLA
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 11-17-2013, 03:31 PM   #12
Liked 1,875 Times in 422 Posts
Alex, my point exactly. And yet, for many applications, I can get an aluminum radiator, fan, and fan shroud combo for not much more than some of the "cheap" import copper/brass radiators alone.
And in answer to another question, I was not suggesting the plastic tank and aluminum core radiators. What I suggested to NHRA a while back was a direct fit, correct dimension, all aluminum replacement radiator. There is no intent to try to stick postage stamp radiators in old muscle cars. At least not on my part.
Old 11-17-2013, 05:03 PM   #13
Todd Hoven
Guest
Posts: n/a
So the rule will be like the SS rule. Anything that fits, as long as it bolts in the factory location? Going to be impossible to regulate any sizes so sounds like anything goes. Another common sense rule for the good of the racers. What is the next rule to change? Aluminum intakes for all?
Old 11-17-2013, 05:23 PM   #14
Not impossible at all. It's pretty obvious whether a radiator belongs or not.
FYI, there are big block cars with six cylinder radiators in Stock right now.
Old 11-17-2013, 05:43 PM   #15
Alex Denysenko
Yup, and I can remember whe you would get pitched for that Alan especially in division 2 or 3 Travis and Wesly territory
Old 11-17-2013, 05:50 PM   #16
There are some tech guys, like Travis and Dave, who know what they're looking at, and would toss offenders if they could.
Old 11-17-2013, 05:58 PM   #17
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
I'm wondering when they'll give the go ahead to put the second 'S' on the class designation. The cars are pretty much de facto super stockers as it is.
Bob Don 128 SS
Old 11-17-2013, 08:45 PM   #18
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I'll try to shorten this story. On Oct 20th I went to Numidia for T+T to make sure I was ready for the Hagerstown combo that was two weeks away. After the second pass I let the car cool for about 45 minutes while chatting with a racer. I decided to make a timing change and as I was timing it I sprung a leak in the lower part of the radiator, it was frustrating but I had no way of fixing it there. Rather than do my own repair as I have done on many street cars I brought it to the most recommended Rad repair shop in the area, while searching everywhere online and Mopar forums to see if I could find a good one, everything I found was junk. On the Wed before the Hag race, the shop told me it was in poor shape and they couldn't promise it would hold but they could recore it for 500 dollars or 150 to try my luck, I said I'll pass on both options. In my basement I had a 3 core version of the one that was in the car that appeared to be in clean shape, I installed it on Thurs eve and it had a small leak in an outer core. Friday I left work for a couple of hours to repair it myself and as I gently removed some fins to remove the bad core I could see this too was nothing but scrap,it was falling apart, I was pretty depressed at this point and knew I'd be staying home.
I was desperate to get some more runs before winter by going to Island Drag and decided to buy an aluminum replacement to use temporarily that was also a bolt in listed for my Challenger which I'm building for SS.
Here is a link to the unit I bought, it required one 1/4" hole drilled to bolt in. http://www.championradiators.com/product/EC2375
Todd, my 50 year old intake is as good as the day it was made, it's dated 5-63, not the same thing here.
Old 11-17-2013, 09:28 PM   #19
Jeff Lee
Jeff Lee's Avatar
My understanding is that in such EPA strongholds as California, it's almost impossible to get an old brass radiator rotted out and repaired. Same reason the days of the chrome plater are pretty much numbered for all but the biggest shops.
I bought a direct replacement aluminum radiator for my AMX while in SS/H off ebay for less than $200. It fills the entire radiator support opening corner to corner, end to end. Cools down a lot faster than the OEM radiator, and is not that much lighter with water. I'm adding a heavy Volvo electric fan and shroud I scored so I'll bet in the end I save no weight at all but I will have a superior cooling system to (hopefully!), go some rounds in the hot days of Arizona.
Jeff Lee 7494 D/S '70 AMX
Old 11-17-2013, 09:35 PM   #20
Robert Swartz
Robert Swartz's Avatar
Shoot Alex, I remember when they argued with you over trim pieces and radio knobs here in Division 3.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
