Old 11-17-2013, 10:18 PM   #1
btrc
Liked 84 Times in 42 Posts
Default Door handle/arm rest on stocker with cage
I am working on a roll cage for a car in stock eliminator. Is it legal to remove the stock door handle and door arm rest to have some extra room for the side bar?
Thanks
Bob
btrc is offline   Reply With Quote
Old 11-17-2013, 10:42 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Door handle/arm rest on stocker with cage
Bob,
You have a PM
Todd Bailey is offline   Reply With Quote
Old 11-17-2013, 10:51 PM   #3
Liked 5,137 Times in 1,960 Posts
Thanks
Bob
I would say... If you move the stock OEM type handle forward or down or reposition the arm rest and redo the upholstery,...No one would even notice or care.
Now , if you want to put a lever style handle sticking out the top of the door panel, like a Super Gas car, I'd say don't try it
Old 11-17-2013, 11:57 PM   #4
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Been told many times by several tech guys that removing the arm rest for roll bar is ok, Door handle mechanisms in Stock must remain stock. Jim
Old 11-18-2013, 07:16 AM   #5
btrc
Thanks for the replies. I can leave the door latch handle where it is. The arm rest is the real problem. Looks like I can remove it though. Thanks again.
Bob
Old 11-18-2013, 11:42 AM   #6
Doug Domm
Liked 84 Times in 21 Posts
Maybe before you ditch the armrest I'd suggest you sit in the car and try closing the door without it. That was one of the things that bugged me about the previous bar in my car is no armrest to grab and close the door. A little creativity on the new bar allows me to replace the armrest now. That's just my preferance. Doug
Doug Domm is offline   Reply With Quote
Old 11-29-2013, 09:25 PM   #7
btrc
It turns out I can't remove my door handle after all. Not because of rules but because it is all one piece. It looks separate but when I pulled the panel off it is one piece.
Is it legal to run the side bar right along the top of the handle and then bend it down to the floor just ahead of the handle? It will still be at the right height where it meets the main hoop. Also how close to the floor does the door bar have to be attached to the vertical tube going through the dash?
Thanks,
Bob
Old 11-30-2013, 01:25 AM   #8
Thanks,
Bob
My understanding has always been that it doesn't matter much where the side bar is mounted (within reason) as long as it crosses between the shoulder and the elbow.
Of course, you would keep the front low enough so you can get in and out.
I always custom bend my side bars so I can open and close the door and not smash my elbow against it when turning the wheel.
This is one of the reasons I don't use roll bar kits.
Old 12-01-2013, 06:35 PM   #9
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Bob
because i wanted my interior to remain all original, we just bent the side bars to go around the arm rests
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 12-02-2013, 07:32 AM   #10
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
x2
