Old 11-19-2013, 03:15 AM   #31
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: Aluminum rads in stock
Just run into this today. Dad's H/PS 93 Mustang GT (that he just drives on street now) had a leak in rad...it's 20 years old with 93,000 miles...well $50 to fix or $85 for a new one....it has a new one in it now....that was from Advance Auto in Jackson Oh.
Old 11-19-2013, 10:11 AM   #32
Jim Kaekel
Liked 535 Times in 110 Posts
2014 NHRA rule changes are up on nhraracer.com. No changes regarding radiators in Stock.
Jim Kaekel 3836 STK
Old 11-19-2013, 01:35 PM   #33
njk53
There are aluminum replacement radiators out there that are a direct fit for a lot of vehicle applications. As stated before, the copper-brass radiators are getting hard to find in some parts of the country and if you can find them, they are expensive. The NHRA should mandate that if you go to an aluminum radiator, you have to mount it in the stock mounting location with the stock brackets and hardware. This will prevent issues with trying to undersize/oversize the radiator for weight advantage.
There may not be an aluminum radiator for every application currently however, I would think if the rule change was made by the NHRA the aftermarket would respond with more applications.
Nelson Kowal
Stock 345
Old 11-19-2013, 04:49 PM   #34
Michael K
Liked 62 Times in 17 Posts
Originally Posted by Paul Precht View Post
while searching everywhere online and Mopar forums to see if I could find a good one, everything I found was junk.
Mopar stock radiators are covered by a shop in Wisconsin, from rebuilds to complete replacements.
Michael K is offline   Reply With Quote
Old 11-19-2013, 05:39 PM   #35
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: Aluminum rads in stock
I glanced at this thread and thought it was about aluminum RODS in Stock.
Good to see it was about radiators,although I'm sure that is next week's rule request.
Old 11-19-2013, 05:52 PM   #36
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
^^^ lol
..or aluminum driveshafts
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 11-20-2013, 07:53 AM   #37
Adam Strang
Liked 96 Times in 23 Posts
I'll try to shorten this story. On Oct 20th I went to Numidia for T+T to make sure I was ready for the Hagerstown combo that was two weeks away. After the second pass I let the car cool for about 45 minutes while chatting with a racer. I decided to make a timing change and as I was timing it I sprung a leak in the lower part of the radiator, it was frustrating but I had no way of fixing it there. Rather than do my own repair as I have done on many street cars I brought it to the most recommended Rad repair shop in the area, while searching everywhere online and Mopar forums to see if I could find a good one, everything I found was junk. On the Wed before the Hag race, the shop told me it was in poor shape and they couldn't promise it would hold but they could recore it for 500 dollars or 150 to try my luck, I said I'll pass on both options. In my basement I had a 3 core version of the one that was in the car that appeared to be in clean shape, I installed it on Thurs eve and it had a small leak in an outer core. Friday I left work for a couple of hours to repair it myself and as I gently removed some fins to remove the bad core I could see this too was nothing but scrap,it was falling apart, I was pretty depressed at this point and knew I'd be staying home.
I was desperate to get some more runs before winter by going to Island Drag and decided to buy an aluminum replacement to use temporarily that was also a bolt in listed for my Challenger which I'm building for SS.
Here is a link to the unit I bought, it required one 1/4" hole drilled to bolt in. http://www.championradiators.com/product/EC2375
Todd, my 50 year old intake is as good as the day it was made, it's dated 5-63, not the same thing here.
Try US Radiator,they have a very good selection.
Adam Strang 1018 STK
Adam Strang is offline   Reply With Quote
Old 11-20-2013, 10:45 AM   #38
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Just checked, aluminum only and they don't look like the original, the one I bought does but I'll keep searching. I called NHRA, they said no aluminum in 2014
Old 11-20-2013, 11:00 AM   #39
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Glen-ray radiators is the company in Wausau, WI , that does the OEM Mopar replacement radiators
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 11-20-2013, 11:20 AM   #40
Run to Rund
Liked 54 Times in 27 Posts
radiatorbarn.com has both copper/brass and plastic/aluminum replacement radiators (at least for my 66 A body).
