Old 11-26-2013, 05:19 PM   #1
Dick Butler
Liked 32 Times in 19 Posts
Default Need info on Factory eliminator
Need someone to update me on the Heads up Factory classes now being proposed or run. THanks.
Are there two or three classes with factors or?
Old 11-26-2013, 05:31 PM   #2
Dave Ley
Liked 241 Times in 44 Posts
Send a message via AIM to Dave Ley
Default Re: Need info on Factory eliminator
FS/AC: Minimum weight up to 400 cid, 3,250 pounds; 401 to 450 cid, 3,350 pounds; 10.50 index
FS/DC: Minimum weight 451-plus cid, 3,200 pounds; all supercharged, 3,500 pounds; 10.20 index
Dave Ley
Dave Ley is offline   Reply With Quote
Old 11-26-2013, 07:11 PM   #3
Dick Butler
Thanks, Dave.
Old 11-27-2013, 04:16 PM   #4
Jeff Teuton
Liked 325 Times in 50 Posts
Subject to adjustment for 2014. More as the political arean heats up.
Jeff Teuton 4022 STK
Old 11-27-2013, 08:02 PM   #5
david ring
david ring's Avatar
By political arena, do you mean the manufacturers. I think more factory involvement is probably a good thing-of course, they will try to work the rules to their advantage, so of course that is something to be on the watch for and try to prevent.
david ring is offline   Reply With Quote
Old 11-27-2013, 09:40 PM   #6
Jeff Teuton
Dave, I meant how much political turmoil I can inflict to make it a good program. Some things became evident this year; blown and unblown don't mix; tech on these motors has to be refined; indexes were a little soft, but I already proposed a fix for that, the manufacturers know what they want, and I don't think any of them will be hard to mold into a fair class for starters. And more as I can think of it. Heads up isn't for everyone, just like Top Stock wasn't for everyone. I like A/FX and B/FX instead of the paragraph you have to put on your car. More races during the year to attract more. Now as far as the AHFS, (speaking of turkeys on Thanksgiving), it needs to be fried like a turkey, but that's a whole nother thread. Just drifting around this cold night down South.
Old 11-29-2013, 05:01 PM   #7
Dick Butler
Jeff keep it up. I know you have the best for the classes at Heart even if you have mopar on your door.
Blown and Unblown dont mix. Gee that took how many months or years to be figured out.
Like carbs and injected. Cannot rate two different animals on same scale.
Wish the factories would agree on cubic inchs and intakes or maybe the lb to cubic inchs would be more accurate than phony HP ratings.
