Old 11-29-2013, 01:04 PM   #1
John Scott
Default 487 vs. 487x heads
What is the difference between 487 and 487x SBC heads? If the guide calls for 487, can you use 487x?
John Scott is offline   Reply With Quote
Old 11-29-2013, 01:46 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: 487 vs. 487x heads
Not sure about those heads off top of my head.I do remember that 461X had different cc runners. Should be able to look up in runner volumes on NHRA.com.
I don't think you can use the X castings unless it is listed in your casting # on engine specs.
Mike Taylor 3601
Old 11-29-2013, 02:43 PM   #3
JRyan
Liked 112 Times in 31 Posts
The difference is that 487X heads have induction hardned seats and rotators from the factory. The 487's simply have a non-hardened seat and normal retainer.
Jerry
Old 11-29-2013, 03:01 PM   #4
John Scott
Jerry, do you think you can use 487x heads if the blueprint lists 487? Are there engines that have 487x specifically listed as the head?
If you search classracer for 487 or 487x there seem to be some posts suggesting the 487x can be used for 1972 200hp 350. That engine doesn't have 487x listed. I'm gathering parts for a 1971 270hp 350 which lists the 487 and not 487x.
Old 11-29-2013, 04:50 PM   #5
Greg Hill
Liked 279 Times in 68 Posts
I've had better luck getting the 993's to flow better than the 487's.
Greg Hill 4171 STK
Old 11-29-2013, 08:22 PM   #6
JRyan
Mac,
I simply don't know. I've never measured the cc's of a 487X to see how they compared to a 487, but I'm pretty sure the port sizes aren't as different as 461 and 461X's ( I think 7cc's now, and it used to be like 10 cc's different).
The casting dates on one of the 487X heads I have is 1971, so it could be that they were used on California cars which may have had a different EPA requirement for unleaded fuels in the early 70's that would have required the induction hardened seats. I think you'll notice on the head that the exhaust valve spring cup is deeper than the intake. They used the same spring on both int & exh., and just sunk the cup. That might have been one of the reasons for designating the "X". Later heads used shorter springs on the exhaust and the same cup depth.
All speculation on my part, but I'm sure there is someone out there that actually knows.
I'm with Greg on the 993's.
Jerry
Old 11-29-2013, 08:56 PM   #7
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: 487 vs. 487x heads
I think the 993's are better than the 487's
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 11-29-2013, 09:08 PM   #8
John Scott
Interesting...thanks guys.
Old 11-30-2013, 05:02 PM   #9
Adger Smith
Liked 880 Times in 311 Posts
Jerry,
Figure this one out.
I have a core supplier that hunts castings. The DT racers around here like the 487X head. He said he had several sets of castings that had 993 on the VC side, but in the water passage hole in the deck it had 487X. Could it be the lower part of the mold was for the 487X and they just mated the 993 top of the mold to them? Economy measure by the casting foundry? Use what they had available? I've always thought the X stood for a blueprint change. I wish I had some of thos 993/487X castings just to look at. Humm...
Adger Smith (Former SS)
Old 12-01-2013, 12:25 AM   #10
JRyan
Adger,
I just looked at one of those 993/487X heads today while arranging my storage. I think they're close to being interchangeable being they're both hard seat heads. GM must have thought so too as they interchanged molds for both as I've seen 993 in the VC area and 487X on the intake runner too. Some of the 993's also have a 493 on the bottom.
Also, I've had a pair of 993's with 152 cc runners. I'll bet the boys with the "Cheatin Bastards" would like those.
Jerry
