Old 11-30-2013, 09:06 AM   #1
426Fred
Liked 2 Times in 2 Posts
Default Hardtop or Post Car
Which 1964 Plymouth body style would be better for stock eliminator, a hardtop or a post car and why? Thank you for any information you could share. I am finishing up a post car but I also have a hardtop I was thinking of converting to a stock eliminator car as well.
Fred Palumbo
1025 STK
426Fred is offline   Reply With Quote
Old 11-30-2013, 10:17 AM   #2
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: Hardtop or Post Car
Fred, I always favored the post cars, I think they twist less than a hardtop.
Bob Pagano A/SA
Old 11-30-2013, 04:17 PM   #3
426Fred
Thank you Bob for you answer.
I have a 64 Plymouth Savoy post car in poor shape body wise and I have a 64 Plymouth Belvedere hardtop in very good shape body wise and was wondering if it would be worth the extra cost to repair the rust and do the body work on the post car. The hardtop just needs some minor dings fixed and a repaint.
Fred Palumbo
1025 STK
Old 11-30-2013, 06:29 PM   #4
Kevin Love
Liked 19 Times in 10 Posts
Depending on what type of rollbar or cage you're going to put in
would probably offset the stength advantage of the post car.
Isn't John Shaul's car a hardtop? I can't remember
I would use the better body as it will be stronger than a body that gets
cut apart and has panels replaced.
Kevin Love 5666 STK/SS
Kevin Love is offline   Reply With Quote
Old 11-30-2013, 06:37 PM   #5
I don't know about the Mopars, but the Chevy II hardtop roof is an inch lower.
I'm not sure it makes any difference though..There are some very fast post cars out there.
Old 12-01-2013, 08:39 AM   #6
GTX JOHN
Liked 2,487 Times in 698 Posts
I raced several 64 Plymouths in the 60s to 70s with Max Wedge
power. I believe the posts were slightly lighter which help
when you could not adjust to class bottoms.
With the cars tied and caged which I recommend I have seen
no difference in stiffness or longevity. The Hardtop does look a little
more Aero.
When the car were not routinely tied and caged.......I did have
flex problems behind Door sill area of Quarters. The sheetmetal
deflected significantly in that area and truck seams seperated.
I could Jack up the car and not be able to get the door open
GTX JOHN is online now   Reply With Quote
Old 12-01-2013, 02:41 PM   #7
art leong
more Aero.
deflected significantly in that area and truck seems seperated.
John we had that problem (the rears wheels trying to catch up with the fronts) With our Challenger convertible. We solved it by putting a bar inside the sill and welding it in 5 places. We were not allowed anything going forward in the roll bar and frame connectors were a no-no.. So we couldn't tie it together any other way. We also used thick wall seamless tubing to help with our weight problems.
Art Leong 2095 SS
Old 12-01-2013, 06:34 PM   #8
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Post cars looks like race cars, hardtops look like show cars.
Old 12-01-2013, 08:42 PM   #9
Tom Meyer
Liked 354 Times in 120 Posts
On the HT chevy IIs there are renforcements in the roof to keep the doors closing right making it weight more, check your shipping weights between the two cars and see what your breaks are for your class that you want to run.
Tom Meyer 5240 SS Stock ???
Old 12-02-2013, 01:56 PM   #10
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
Here is a good picture comparison of the two Chevy II models. Our post Chevy II doors didn't close right when the car was jacked up until we went with a cage and a sill plate bar (2nd pic) for additional support.
sill post view
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
