Old 12-02-2013, 12:20 PM   #11
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Stocker info needed
Originally Posted by H.A.A.C. Racing View Post
OK, its a "nomad custom" I'm coming up with
327 250 HP is 14.47
327 275 HP is 13.49
3787.50 for 250 HP
3709.75 for 275 HP
Does this look correct?
Yes, the 'factors' are correct.
327/250 fits at the bottom of M/SA, so you can run L and N also. Minimum weight is 13.50 (L), 14.00 (M) aand 14.50 (N) x 245 (the NHRA Rating on the motor) plus 170 (for driver weight) = min wt, across scales, with driver.
L/S-L/SA = 3,477.5 minimum weight
M/S-M/SA = 3,600 min wt
N/S-N/SA = 3,722.5 min wt
327/275 has been derated to 265 in Stock. Same rules apply. 13.49 is the very bottom of K/SA, you can run J and L also. SO you would use weight break (12.5 for J, 13.00 for K, 13.50 for L) x 265 + 170 = minimum weight at conclusion of run with driver.
Old 12-02-2013, 12:28 PM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
327 250 HP is 14.47
327 275 HP is 13.49
3787.50 for 250 HP
3709.75 for 275 HP
I was looking at Malibu station wagon, but I'm not up on the wagon nuances. If it is what you say here is the way it would shape up -
327/245 - 14.29 @ natural M is 3501lbs + 170lbs driver weight = 3671lbs. Minimum weight @ M would be 3430 + 170 = 3600.
327/265 - 13.32 @ natural K is 3530lbs + 170lbs driver weight = 3700lbs. Minimum weight @ K would be 3445 + 170 = 3615.
Rich Taylor
I/SA - 321
Old 12-02-2013, 08:01 PM   #13
H.A.A.C. Racing
H.A.A.C. Racing's Avatar
I found it under chevelle.......it is badged chevelle nomad custom. They are origional emblems because my father has owned the car ever since I could remember (I was born in 73). Thats how I found the numbers I posted earlier.
I found a compression, carb, cylinder head, intake, bore, stroke, rod length. Is that it? No cam rule or do they just figure you can only fit so much in that package. Does it have to be a powerglide or can it be a 3 speed?
H.A.A.C. Racing is offline   Reply With Quote
Old 12-03-2013, 02:11 AM   #14
HandOverFist
OEM lift which is 390/410 for the 327's, any duration. Look at the blueprint spec's for 1968 and it will show all carbs, heads, intakes, ect. for those combos...some parts may be superseded and aftermarket allowed. Any transmission with a maximum of three forward speeds allowed, same manufacturer as car. Between the rulebook, blueprint guides and aftermarket approved products you should be able to get a good grasp of what is needed. Plenty of folks here will be glad to answer questions as they come up I'm sure.
Rich Taylor
I/SA - 321
Old 12-03-2013, 01:30 PM   #15
H.A.A.C. Racing
You guys have been a big help already, thank you.
Old 12-03-2013, 03:49 PM   #16
Fireofficer5
Liked 33 Times in 20 Posts
So, how does how does a fat *** driver like me make the weigh?
Am I balast to move up a class?
I'm 265 lbs.
I want to try my 96 Cougar at the Orlando D2 race.
Fireofficer5 is offline   Reply With Quote
