Old 12-03-2013, 06:24 PM   #1
John Lang
Liked 6 Times in 2 Posts
Default Acumulators
Any body got an ideas about brand of oil accumulators, as far as good or better than other ? What capacity size to use ? I'm in need of one, and don't want to make a wrong choice !...Thanks John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 12-03-2013, 08:16 PM   #2
JimL
Default Re: Acumulators
I have a 3 quart Moroso, works great.
JimL is offline   Reply With Quote
Old 12-04-2013, 08:34 AM   #3
richie 2
Liked 205 Times in 93 Posts
which capacity is required or better for a S or SS sbc....
Old 12-04-2013, 09:05 AM   #4
Todd Hoven
Guest
Posts: n/a
I'll add to this thread with a question. How are guys controlling them? Manual 1/4 valve, electric valve with a pressure switch? What size line do you run from one? Thanks
Old 12-04-2013, 08:29 PM   #5
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
I have the Moroso 3 quart with an electric valve. I have it wired into the ignition so when you turn it on, the oil is dumped into the system. I use a remote filter with #12 line. I think it is a great value/option to add to any race engine. No more dry starts and no loss of oil pressure after the finish line.
Old 12-04-2013, 10:36 PM   #6
JimL
I have the 3/4 inch ball valve that comes with it so I can turn it off if I need to work on the system. For race operation, I have a solenoid valve in the -12 line and a switch on the dash that the driver turns on first, observes 20 psi on the oil pressure gage and fires the engine up. He then turns that switch off first before killing the engine. As mentioned above, you never start a dry engine this way. I love it.
