Old 11-25-2013, 08:41 PM   #1
art leong
Default Generator priming bulb?
I have a Lifan generator. That has a bad (leaking) priming button (bulb). I took it apart and it only has one fuel line going to it.
The generator is made in China so I might not be able to get parts for it.
Other than that it runs fine.
What can I use to replace it?
Art Leong 2095 SS
Old 11-25-2013, 09:58 PM   #2
FED 387
Liked 333 Times in 180 Posts
Exclamation Re: Generator priming bulb?
Artie --Try Lifan Power USA they are located in Van Buren Arkansas 866-471-7464 8AM- 5PM M-F - that's customer service see where ya get--- FED 387
Old 11-25-2013, 10:05 PM   #3
tj310
Default Re: Generator priming bulb?
I've had that problem with my chainsaw for 5 years . I just plugged it and use ether Kinda hard to justify a repair on a saw I can buy new for 150$. I did drill a hole in the housing so it can be sprayed without removing the air filter. ---Trevor
Old 11-26-2013, 07:51 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Check with any reputable small engine repair shop...chances are they may have something that will work.
Rich Taylor
I/SA - 321
Old 11-27-2013, 06:08 PM   #5
art leong
Thanks called and ordered the part.
Art Leong 2095 SS
Old 12-04-2013, 04:40 PM   #6
art leong
Got the part. Put it on . The generator started up easier than it ever has (cold in cool weather) and it was 50 degrees. I always had a fight with it at anything colder than 65 degrees or warmer. Easiest starting was in 90 degree weather.
Was always happy with the generator once it got started. Carries the load well, good on fuel, etc.
Art Leong 2095 SS
