Liked 33 Times in 16 Posts
Anyone have a reliable link/source for U-bolts for a Chevy 12-bolt housing? I'm in need of 8' to 9" length due to the use of lowering blocks.
Rich Taylor I/SA - 321 |
Liked 16 Times in 11 Posts
Go to your local spring repair shop, they can make them any length you need.
Bob Pagano A/SA |
If I understand correctly Chevy uses a 3-1/16" inside dimension?
Liked 799 Times in 236 Posts
Just had a local spring shop do these for a Nova mono leaf 12 bolt:
![]() 3 1/8" inside-to-inside and 7 1/4" leg length (measured from the outside top of the 'u'). When installed, there is 2" of thread below the Cal Trac mounting plates. Not the exact info you asked for, but might give you some reference for length.... -Al P.S. I like the Camaro build pics.
"That'll never work....." |
Guest
Posts: n/a
My local parts store had them in stock.
Yeah, I need at least 8" because of the 1" lowering blocks on our car. I don't know of anyone local in my parts.
Rich, Jegs has these 9.5" u-bolts on hand:
http://www.jegs.com/i/AFCO/921/20238-9/10002/-1 Hope this helps. -Al
Liked 8 Times in 7 Posts
I picked up a set at napa in the 4x4 stuff...had to buy a kit w/lowering/raising blocks but they look cool hanging on my wall
without losers,winning means nothing. |
Liked 54 Times in 27 Posts
I got some u-bolts here:
http://www.autoandtrucksprings.com/ |
#10 | |
Perfect Alan - I was looking at a set there earlier but they would not have them until the 18th. Don't know why these didnt show up in the search. Edit: Just found the same ones on the Summit site as well... http://www.summitracing.com/search/p...0Leaf%20Spring
Rich Taylor I/SA - 321 Last edited by HandOverFist; 12-08-2013 at 01:01 PM. |
