Old 12-09-2013, 10:52 AM   #1
Lyn Smith
Liked 994 Times in 200 Posts
Default GM points to electronic distributor conversion
Im trying to copy a conversion i saw on the internet that converts a Gm points distributors to electronic(street applications) by using a chrysler reluctor,and pick up coil,and a GM 4 pin module mounted under the distributor.What coil could you use for this?Would a hi per accel coil for non HEI work? thanks
Old 12-09-2013, 01:04 PM   #2
peteprostock
Default Re: GM points to electronic distributor conversion
Lyn .. www.pertronix.com is a big player in conversion kits for like hundreds of applications
peteprostock is offline   Reply With Quote
Old 12-09-2013, 03:07 PM   #3
njk53
I believe Accel also has a conversion unit. Both are supposed to be good parts.
Nelson Kowal
Stock 345
Old 12-09-2013, 03:23 PM   #4
Joe Toller
Liked 9 Times in 9 Posts
A canister coil will work, but an even better option is the electronic coil from a late 80's on up EFI Ford. They are cheap and around 40,000 volts from the factory.
Old 12-09-2013, 03:30 PM   #5
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Hey Lyn,
Are you referring to Dave's Small Body HEI distributors: http://www.davessmallbodyheis.com/
If so, they use a normal GM 12Volt Coil.
Glenn
Old 12-09-2013, 04:50 PM   #6
njk53
The Accel and Pertronix conversions are designed to fit in the original point distributor so it looks stock. Actually the Ford Coil is a good pick because it isn't an oil cooled unit like the MSD Blaster. Get the wire harness from any junk yard, buy a new unit and you are good to go.
Nelson Kowal
Stock 345
Old 12-09-2013, 05:15 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
There is also a Mallory Unilite Conversion, that I have used in the past.
Old 12-09-2013, 06:22 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I just put a Pertronix conversion in a Ford distributer .
Took all of about 15 min. Fit perfect , works great .
Old 12-09-2013, 06:27 PM   #9
Glenn Hayes
I've been using the Crane XRI Kit since they came out with them.
They work great!
http://www.summitracing.com/parts/cr...make/chevrolet
Old 12-10-2013, 09:48 AM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I use pertronix Ignitor III on restorations has a protection circuit built in that protects it from burning up and has adjustable built in rev limiter,and installs easier than a set of points,which is easy.
Has anyone had the experience of being considered a automotive genius,because you can install a set of points,or build a carb.LOL
Mike Taylor 3601
