Liked 1,001 Times in 203 Posts
Im trying to copy a conversion i saw on the internet that converts a Gm points distributors to electronic(street applications) by using a chrysler reluctor,and pick up coil,and a GM 4 pin module mounted under the distributor.What coil could you use for this?Would a hi per accel coil for non HEI work? thanks
Lyn .. www.pertronix.com is a big player in conversion kits for like hundreds of applications
I believe Accel also has a conversion unit. Both are supposed to be good parts.
Nelson Kowal Stock 345 |
Liked 9 Times in 9 Posts
A canister coil will work, but an even better option is the electronic coil from a late 80's on up EFI Ford. They are cheap and around 40,000 volts from the factory.
Liked 18 Times in 12 Posts
Hey Lyn,
Are you referring to Dave's Small Body HEI distributors: http://www.davessmallbodyheis.com/ If so, they use a normal GM 12Volt Coil. Glenn
"Real Race Cars Have Tailgates" |
The Accel and Pertronix conversions are designed to fit in the original point distributor so it looks stock. Actually the Ford Coil is a good pick because it isn't an oil cooled unit like the MSD Blaster. Get the wire harness from any junk yard, buy a new unit and you are good to go.
Nelson Kowal Stock 345 Last edited by njk53; 12-09-2013 at 04:53 PM. |
Liked 239 Times in 114 Posts
There is also a Mallory Unilite Conversion, that I have used in the past.
Liked 886 Times in 238 Posts
I just put a Pertronix conversion in a Ford distributer .
Took all of about 15 min. Fit perfect , works great .
I've been using the Crane XRI Kit since they came out with them.
They work great! http://www.summitracing.com/parts/cr...make/chevrolet
Liked 317 Times in 108 Posts
I use pertronix Ignitor III on restorations has a protection circuit built in that protects it from burning up and has adjustable built in rev limiter,and installs easier than a set of points,which is easy.
Has anyone had the experience of being considered a automotive genius,because you can install a set of points,or build a carb.LOL Mike Taylor 3601 |
