#151 |
Liked 780 Times in 194 Posts
Consider allowing any rwd car regardless of year. Maybe some restriction to keep exotic cars out. The gen III F-body cars were serious MP cars, i.e. Coleman Roddy. Also, a mid-80s Mustang or other Fox platform FoMoCo would be cool. Heck, even a new Mustang, Challenger or Camaro would be a cool MP car. Can you think an LS engine, a modular V8 or a new hemi with a tunnel ram?
#152 |
Liked 32 Times in 19 Posts
Needed some guys with rollers in the garage to play.
#153 |
Liked 22 Times in 22 Posts
I'll let qualified SS racers use those engines for a match race. I suppose we could run one at 9, or 9.5 lbs. and the other at 10.5, or 11 lbs. per cube. They need to give me a little time to get them ready. The two 750 cfm carbs run nearly identical on the track, and the dyno. The LS engine deal, I don't know. Doesn't interest me, but, like I say, if that's more popular, knock yourself out. It just ain't for me.
don,t have one |
#154 |
Liked 91 Times in 29 Posts
I think 3 classes 9.5 , 10.5 and 11.5 ci per pound 360ci max. Spec type head , 12.5comp max. No exotic valve train. 750 max lift cam. No custom grinds, off the shelf only. Crank trigger ok. Single 4bbl with 950cfm or dual 4bbl with 660cfm each max. No exotic carb mods. Cast manifolds with port matching only. 4 or 5spd trans using a clutch to shift. Single disc only.
#155 |
Or, 9, 10, and 11 lbs. per cube. Max 360 fine. Min. wt. 3,000 lbs. I do know in my experience, 2 fours is a tenth quicker then my best single four. Love everything about your idea but the 12.5 compression. With these heads, and even 360 cubes, it's hard to get 13.5 to one. I know they'll do it, but really don't see an issue. Anyone willing to furnish the car? Come on guys. I need a little time. Look, if you blow it up, it's no skin off your ***. I'll just be out a motor. I'm not asking anyone to loan me a car, just be the test pilot for this.
don,t have one |
#156 | |
Liked 7 Times in 7 Posts
Think 1-CLASS...1-CARB....and stick-ONLY...is a good way to start...You already got TONS of auto trannys out there...Nothing against 2x4 set-ups...but single is SIMPLE... Give the class a chance to run and feel it out....I know we've been here before...it'll feel a LOT like 1975-ish A/SM class....weight breaks came later....RIGHT?? Think the "stick" approach will make this way a bit unique or "different"...Having auto] trans will make it seem like SS or Stk...at least to the casual spectator...IMHO... btw...I'm NOT a player in all this...don't have a car or motor....but WOULD like to see it HAPPEN.... Just sayin...... |
#157 |
I have ideas to make it real simple, real affordable, and really easy to police. And also, real entertaining, and real competitive. But, these are just my ideas, and don't expect everyone to agree.
don,t have one |
#158 | |
Liked 13 Times in 11 Posts
8 ,9 lbs...need to keep the weights down . Fiberglass OK , but limited and must appear stock , retaining trim etc etc. Absolutely 2 -4s and head limitations. 4 or 5 speeds. Automatics? Really? In modified style cars? |
#159 |
Don't matter to me what pounds per cube you allow, but most SS cars are in the 3,000 range. Min. WT. And max. WT. Should cure that. Ran at 3,000 lbs. My whole life. And constant breakage is not a problem
don,t have one |
#160 | |
What I was saying is that at 10 and 11 lbs you will encourage it. I assume you're implying the conversion from SS to this suggested class / classes when you referenced the 3000 lb point. They can start at 3000 and work downward. Ref. my suggestion of 8 and 9lbs. They'll run quicker ( more fun for driver and fans alike ) and be a little easier on parts ( as you know ). To keep this stuff healthy the cars need to be quick.......read that spectator appeal. But I'm sure you already know THAT as well. There is a resurrection of vintage gassers running all over the country.........I've seen some of them......They're cool as hell and quick too. [ame="http://www.youtube.com/watch?v=rgZs1Ujd7is"]Run Ragged -vs- Bone Shaker - YouTube[/ame] No reason someone couldn't create a vintage Modified eliminator circuit? |
