This list is a balanced assembly and I have balance sheet:
1.New 302 crank with cryo work done 350.00 1.New #870007 TCI Rattler Balancer 225.00 1.Used Crower Sportsman Rods 200.00 1.87-95 Venolia Stocker 4.030 Pistons and Pins 450.00 1.New #529618 TCI Automatic Flywheel 65.00 I have marked this assy. done to 1290.00, but will take 1150.00 and you pay the freight 2. Motorsports Sportsman block. Bought as a shortblock then dis-assembled to use for this. It is std. bore. 600.00 3. 1 pr. E7TE stocker heads fresh done and no skunk work prepared by Wesley Roberson 450.00 4. New #16100 Canton Fox Body Pan w/windage tray and ARP bolts 200.00 5. New Ford Motorsports Hyd. Roller Lifters worked by Allen Sherman 200.00 6. New #8138 Comp. Cams Roller Timing chain assy. 100.00 7. New Bullet roller billet camshaft 150.00 8. New Alum. Timing Cover 40.00 9. New Edlebrock Air-gap Performer manifold 200.00 10. Used 302 MSD #8582 Dist. 125.00 11. New #8455 MSD dist 94-95 Electronic 240.00 12. Used MSD #7210 7-A ignition box 100.00 13. New Tall Plain Polished Valve Covers 25.00 14. New Polished Electric Water Pump 100.00 15. New ARP Head Bolts 25.00 16. New #4505 Comp Cams 3/8 Rocker Studs 30.00 17. Used BG280 fuel pump w/brackets 100.00 18. New #13301 Aeromotive by-pass regulator 100.00 19. New TCI 8" convertor ssn/CSSX-5 call Gary Bruce@ TCI for info 350.00 20. New #616332 TCI Outlaw shifter 180.00 21. New 15x4 Weld ProStars, mounted never ran 250.00 I have Listed these items seperate from upper, whole package is 4855.00 and can be bought for 4650.00. You pay freight I am getting out of racing, I have no time to travel and not interested in bracket racing. 601-942-3131 after 6:30 pm eastern or e-mail racingfrog56@aol.com Last edited by Larry Ingram; 09-02-2007 at 09:38 PM. Reason: left out address |
Make any resonable offer, Items have to go, Thanks
Liked 79 Times in 11 Posts
larry you have a pm.
Liked 1,032 Times in 283 Posts
Larry, I also sent you a pm because your email doesnt work
Looking for a stock 4150 base carb intake for 1985 Mustang 5.0
Also, Upper and Lower intake and Throttle body for 1989 Mustang 5.0 |
These parts have a deposit on them as of now, will repost if deal falls through. Thanks for looking
