Liked 4,379 Times in 502 Posts
I'm looking at a 96 and a 97 this weekend. One is the Chevy 454 and other is ford 460. Can't find any numbers on the hitches and wondered if these were able to tow my 22' enclosed with race car in.. Guessing roughly 7000 lbs?
Liked 80 Times in 28 Posts
Bobby
Chances are it has a factory 3000 - 5000 lb hitch on it but there are some areas to look at before hitching up Few things to consider -length of motorhome/overhang (can affect handling) -beef of frame to the back bumper? - I think Ford has 16" rims/Chev should be 19.5" (better tires and less sidewall) You will want to consider boxing/beefing the hitch both to prevent chassis flex and Motorhome Delamination as well as peace of mind that the trailer stays attached ![]() The last two years I towed with a '99 Chev chassis (31' Motorhome) 454 vortec and a 4sp 4L80E towed a 20' V nose with a Super Stock car with no issues Feel free to PM me for more details |
Ok the Chevy is 30' long and the ford is 34' long. Can I take it to a shop to get a stronger hitch put on? Also, what are the most common problems with motorhomes and what should I be looking for as soon as I get in it?
Liked 327 Times in 121 Posts
Call John at DRC race products 570-658-3515. He did a great job on my old motorhome hitch, his craftsmanship is a work of art.
Bobby,
Look for the following * Any Delman? Roof in Good Shape? *Open every compartment and feel around the roof for soft or wet spots *Exhaust Manifolds - Make sure no leaks or broken studs *Try to test all appliances Fridges, AC's etc. are very expensive to fix You can beef up the hitch. Not a big job. The less overhang the better. The bigger the tire and weight rating the better |
Thank you Mark.
Liked 460 Times in 91 Posts
Bobby call me. The coach I use has a redone hitch. You can see it in coatesville.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
