Old 09-17-2007, 09:31 AM   #51
bsa633
Banned
Default Re: AA/S AAA/S and Class consolidation
If consolidation of regular and FI classes happens and will show that fi cars have an advantage over the older cars...1:most guys will switch to newer cars 2:the guys with the older cars will stop coming to the events...
bsa633 is offline   Reply With Quote
Old 09-17-2007, 11:53 AM   #52
Jeff Teuton
Liked 325 Times in 50 Posts
Looking at the figures on EFI vs Old Stuff. A/SA vs A/FIA (using Nitro Joe's numbers) averages .032 better for the EFI, C/SA vs B/FIA (9 lbs/hp) is worse @ .106 better and I am waiting for the comparison for E/SA and C/FIA. There aren't enough stick shift EFI cars to have much average. And this is only using runs of .50 under or better. And of course you could compare all the classes. Joe's numbers have national and point races. I am trying to get the comparison numbers on what NHRA has in these classes. There is no direct comparison for B,D,F, etc because EFI classes are 1 lb per hp at each level where B,D,F etc are .5 lb/hp. Ok I just ran the numbers and well let Joe verify them when he calls. C/FIA is 1.009 under for an average and E/SA is .917 under or .092 better for the EFI.
Old 09-18-2007, 09:54 AM   #53
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
What about the new possible weight breaks? I'd like to know what combinations would be possible for them whether new or old?
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is online now   Reply With Quote
Old 09-30-2007, 06:41 AM   #54
bsa633
Banned
sportnats* Stock = first round 3 headsup,would have been 5 with the "consolidation" but then you dont know who slides over to AA and in what class the particular FIA cars actually land! I woulda guessed more headsup than that..
