Old 12-17-2013, 01:22 PM   #1
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Default Pure Stockers New Camshaft Rule !!!
From the 2014 IHRA Rule Book... Pure Stock lost a little "Purity" today .. This is posted for the guys who might have a cam on order or will be soon..
12/10/13
p. 48 Pure Stock: Camshaft: Camshaft must retain stock lift for horsepower claimed per IHRA Technical Bulletins. OEM duration and overlap is optional
Can't get too crazy as the valve springs still have to check at OEM pressures, open and closed. Guess this was changed to speed up tech / tear down or maybe lack of data supplied by the OEM's?
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 12-17-2013, 01:32 PM   #2
Tar Heel
Guest
Posts: n/a
Default Re: Pure Stockers New Camshaft Rule !!!
12/10/13
Wow! Thanks for posting that. Thanks also to IHRA for changing this a few months after I had Bullet grind a Pure Stock cam with STOCK duration. I could have really went fast if I wasn't restricted to that. Ugh!
Old 12-17-2013, 02:39 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Sounds like 10 second pure stock cars are just around the corner!
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-17-2013, 03:29 PM   #4
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
12/10/13
What does OEM duration and overlap optional mean?
OK.. emailed Mike Baker ..and it is true.
Can use any OEM Spring.
This is Mike's response to my email..
"If it is oem design and size it is ok"
D
Old 12-17-2013, 03:38 PM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
D
I think it means they didnt want to copy/paste the NHRA rulebook for Stock...not a bad idea in itself.
Rich Taylor
I/SA - 321
Old 12-17-2013, 04:20 PM   #6
Lyn Smith
Liked 1,002 Times in 203 Posts
I can finally retire my General Kinetics special Pontiac lobe(thats what they called it even though it was in a Buick) stock duration cam i had made in 1980 .I think i will mount it on a board and put it on the wall in the man cave.LOL
Old 12-17-2013, 05:08 PM   #7
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
I know one that will go 10s 67 vette 427- 400 for sure.
Bob Pagano A/SA
Old 12-17-2013, 05:37 PM   #8
FINESPLINE
FINESPLINE's Avatar
Do you think the IHRA just cracked open their version of Pandora's box by loosening the camshaft rules ?
FINESPLINE is offline   Reply With Quote
Old 12-17-2013, 07:03 PM   #9
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Holy Cow !
As an owner of a Pure Stocker, I'm not sure if that is good or bad ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-17-2013, 07:11 PM   #10
ALMACK
ALMACK's Avatar
D
Dan:
Am I reading this correctly ?
ANY valve spring can be used (regardless of measured pressure) as long as it looks OEM ?
I/PS '95 Mustang GT
