Old 12-17-2013, 07:36 PM   #11
Rick Schilling
Liked 14 Times in 10 Posts
Default Re: Pure Stockers New Camshaft Rule !!!
Originally Posted by ALMACK View Post
Dan:
Am I reading this correctly ?
ANY valve spring can be used (regardless of measured pressure) as long as it looks OEM ?
I'm seeing the new cam rule in the 2014 rule book but it still reads the same as before for the springs.
Maybe it just hasn't made it into print yet but I'm going to wait until I see it in black and white.
Rick Schilling is offline   Reply With Quote
Old 12-17-2013, 07:50 PM   #12
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
[QUOTE=Dan Fahey;412873]What does OEM duration and overlap optional mean?
OK.. emailed Mike Baker ..and it is true.
Can use any OEM Spring.
This is Mike's response to my email..
"If it is oem design and size it is ok" QUOTE
Better get that in writing or amend it in the rule book cause look at page 49 2014 rule book,
VALVE SPRINGS:
Stock replacement per OEM spec. and must check on factory spec.
open and closed pressure
Pandora's Box
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 12-17-2013, 09:34 PM   #13
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Originally Posted by Lyn Smith View Post
I can finally retire my General Kinetics special Pontiac lobe(thats what they called it even though it was in a Buick) stock duration cam i had made in 1980 .I think i will mount it on a board and put it on the wall in the man cave.LOL
I love that idea!!!
Lane Weber
Old 12-17-2013, 10:10 PM   #14
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Pure Stockers New Camshaft Rule !!!
I'm thinkin' the indexes will need to be adjusted now. Jim
Old 12-18-2013, 01:45 AM   #15
John Kelley
Red face Re: Pure Stockers New Camshaft Rule !!!
NOT "pure" anymore.......if they ever were..... :-(
John Kelley is offline   Reply With Quote
Old 12-18-2013, 09:33 AM   #16
gbur
Whole new can of worms. Should be original cam from manufacturer,same for springs. My opinion. If you can't go fast with what you have, you need to work harder.
gbur is offline   Reply With Quote
Old 12-18-2013, 09:36 AM   #17
Tar Heel
Guest
Posts: n/a
Originally Posted by countrypuppy4865 View Post
Sounds like 10 second pure stock cars are just around the corner!
Perhaps. We were in Dallas for their Thanksgiving race and the air was well below sea level. Went 11.58 with a 1.50 60' 150 lbs. heavy for B/PS. I'm not sure if there would be 4 tenths in an unlimited duration cam with any spring but we haven't been in the heads yet either.
I like the rule; just wish I would have known it two months ago before I changed the cam and springs.
Scott
Old 12-18-2013, 09:38 AM   #18
Tar Heel
Guest
Posts: n/a
Good idea. I don't know that some weren't soft before.
Scott
Old 12-18-2013, 09:56 AM   #19
gbur
Scott
Wasn't that with bogus gas ?
Old 12-18-2013, 10:17 AM   #20
Tar Heel
Guest
Posts: n/a
No, we were legal. It still has the oxygen sensors so we have to run unleaded.
Scott
