Old 12-17-2013, 11:55 PM   #11
7423
Default Re: Pure Stock/Stock help 91 LX 5.0 Conv.
Originally Posted by ALMACK View Post
Welcome to class racing.
I agree on the posts above about an aftermarket torque convertor. Mine really needs one.
I have a '95 Mustang GT Pure Stocker with basically the same engine as the Fox Mustang except mine has the factory electric fan.
Mine also has the AODE.
The car still has the factory torque convertor and has run a best of 9.29 on the I/PS index of 9.45.
Car still has the factory front and rear springs, struts, shocks, and sway bars.
Lots of room for improvement.
Alan
I have the AODE with a 2.84 low gear set and a 9" Edge convertor that I ran in my car before the current C4. If you have an interest in them, email me at socalvega@aol.com
7423 is offline   Reply With Quote
Old 12-18-2013, 09:08 AM   #12
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Ours is a 89 Conv and we have it in I/PS. 167,000 miles and valve covers never been off!
4.56
TCI street fighter
Long tubes
275 60 15
Best is 8.75 last month @ fayettville loose rocker race.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 12-18-2013, 02:29 PM   #13
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Originally Posted by west coast View Post
On the rear end I would skip the c-clip eliminator and cut the ends off and weld 9" ends on since you are going to buy axles. C-clip eliminator have a tendency to leak. No pure stock classes out here, don't know if you can change the brakes while you are there.
This is a copy-n-paste from the IHRA rulebook:
BRAKES: Must be OEM complete, Line lock accepted. OEM up grades allowed.
So, I take that to mean no Aerospace, Strange or other aftermarket brakes ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-23-2013, 03:51 PM   #14
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Smile Re: Pure Stock/Stock help 91 LX 5.0 Conv.
Correct......OEM brakes only or OEM up grade(OEM later disc for something like a 57 Chebbie).....unless IHRA made a last min. rule change????
Old 12-23-2013, 04:31 PM   #15
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Probably of no help here...mostly older conversions. https://scarebird.com/index.php?route=common/home
Rich Taylor
I/SA - 321
