Old 12-18-2013, 11:39 AM   #21
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Pure Stockers New Camshaft Rule !!!
What does OEM duration and overlap optional mean?
OK.. emailed Mike Baker ..and it is true.
Can use any OEM Spring.
This is Mike's response to my email..
"If it is oem design and size it is ok"
D
You better get clarification on what Mike says. "If it is oem design and size it is ok" says nothing definitive about pressure.
Old 12-18-2013, 12:09 PM   #22
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Here are the emails back and forth from Mike last night!
Sent: Tuesday, December 17, 2013 3:33 PM
To: Daniel Fahey
Subject: Re: Pure Stock Spring VS574 - Checking for Legality
Yes
Sent from my Verizon Wireless 4G LTE DROID
Daniel Fahey wrote:
So if the Spring Pressure is 30% above Stock it will be OK?
Just so long as it is a Stock Replacement Spring!
Correct?
D
Daniel Fahey - CEO President
DanSources Technical Services, Inc.
1010 Rockville Pike, Suite 405
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Sent: Tuesday, December 17, 2013 3:25 PM
To: Daniel Fahey
Daniel Fahey wrote:
Hello Mike:
Called Bullet Cams for advice…
He asked me to confirm on my LT1 1995 SBC Engine.
My Car runs G/Pure Stock. 1995 Impala SS.
Looking at a replacement spring from Associated Spring VS574..
Lists as a LT-1 replacement spring.
Need to know if it qualifies as a Pure Stock Legal Spring for my car.
Dan
Rockville, MD 20852
301-217-0425 x 400
www.DanSources.com
Old 12-18-2013, 12:13 PM   #23
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Keep in mind a email assurance does not hold the sway of a rulebook. Tech inspectors do not carry copies of emails.
"Stock replacement per OEM spec. and must check on factory spec. open and closed pressure."
Rich Taylor
I/SA - 321
Old 12-18-2013, 12:31 PM   #24
Dan Fahey
Dan Fahey's Avatar
YES..just sent him another email asking that question.
As for 10 Second Pure Stockers.
Here is a link of the first 9 Second ET in Stock history.
Bobby DeArmond...May 9, 2001
http://www.nhra.net/fedmog/2001/news/may/050901.html
Dan
D
Old 12-18-2013, 01:45 PM   #25
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Do I have to e-mail Mike Baker to get the spring pressure numbers for my car ?
I sure hope IHRA leaves the indexes alone and just adjust the super fast PS combos with h.p.
If IHRA changes the indexes, I will probably just upgrade my Mustang to NHRA Stocker specs.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-18-2013, 01:45 PM   #26
Dan Fahey
Dan Fahey's Avatar
OK..Mike just emailed me again.
So long as the Spring fits in the Original Stock Pad.
The Spring is legal.
More cam and spring would eventually necessitate resetting the Pure Stock Indexes.
Kind of wished they did not do that. We are in Junior Stock Range.
Keeping the Stock Spring pressure would add only a little HP.
This change Pure Stock should be renamed Jr Stock again!
err
Dan
Old 12-18-2013, 01:53 PM   #27
ALMACK
ALMACK's Avatar
Maybe Pure Stock should be renamed Jr Stock again!
err
Dan
Interesting.
Then there should be an amendment to the specs book stating:
"So long as the Spring fits in the Original Stock Pad.
The Spring is legal."
As posted before in this thread, I would think the rulebook trumps any e-mail on raceday in the teardown area.
I/PS '95 Mustang GT
Old 12-18-2013, 01:55 PM   #28
Dan Fahey
Dan Fahey's Avatar
Originally Posted by ALMACK View Post
Interesting.
I agree...
Old 12-18-2013, 03:36 PM   #29
Tar Heel
Guest
Posts: n/a
So what will be the difference now between what a Pure Stock cam is and what a "normal" Stocker runs? Sounds like to me it will be the same cam. How much do you expect it to pick up the typical combination (if there is such a thing)?
The more I've thought about this today the less of a good idea I think it is.
Scott
Old 12-18-2013, 03:46 PM   #30
Bobby DiDomenico
Liked 101 Times in 52 Posts
Scott
Agree. Might be easier for tech, but now it would just be stock eliminator with mufflers?
