Old 12-19-2013, 03:29 PM   #11
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Default Re: HP Adjustments - New Combo's Added
Originally Posted by SuperCarFan View Post
On www.nhraracer.com, I did not see the 2014 info for the Camaro or Ford. Where are you guys seeing the ratings? Thanks.
Ford:
http://www.nhra.net/tech_specs/class...s/2014FORD.xls
http://www.nhra.net/tech_specs/engin...ts/FORD-14.rtf
kdanner is offline   Reply With Quote
Old 12-19-2013, 03:38 PM   #12
kdanner
kdanner's Avatar
Originally Posted by kdanner View Post
One 2014 302 combo is 350hp in some places yet 330 in others, and the head casting numbers for it don't agree with the given valve size.
Well this got partially corrected already, it's now the same HP as the 2013. Valve size still needs fixed.
Shipping weight was raised compared to 13, so the 14 can fit in C, or even D if a stick.
Old 12-19-2013, 03:56 PM   #13
SuperCarFan
Thanks. Guess the www.nhraracer.com links are older.
SuperCarFan is offline   Reply With Quote
Old 12-19-2013, 08:42 PM   #14
Tom Moock
Liked 10 Times in 6 Posts
1964-1966 Chevy Chevelle HP change in the guide from 220 to 217 in SS as of 1-1-14, but not listed in the new adjustments just released? Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 12-19-2013, 09:43 PM   #15
Tom Meyer
Liked 354 Times in 120 Posts
Same engine in a chevy II is 236 that's 19 hp less. So if I would race a chevelle in SS/LA a 13 lb class it could be 247 lb lighter than a chevy II with the same engine. How much ET would that be worth .Also why would you what to run SS/LA when you could run SS/MA where there is 4 tenths difference in index and only 2 tenths between L and K. Tom
Tom Meyer 5240 SS Stock ???
Old 12-20-2013, 01:06 AM   #16
JRyan
Liked 112 Times in 31 Posts
Tom,
If you can get a '65 Chevelle down to 2990 with driver for SS/LA -- you be cheatin'. Time to break out the old 4-door again. When we last ran it, it was 3460 lbs. for SS/MA. Now, it's only 3425 lbs. for SS/NA, and 3210 for SS/MA.
But heck, racing the Chevelle against your Nova II is like a Clydesdale against a throughbred. You deserve at least some of that 17 HP. \
Jerry
Old 12-20-2013, 01:09 AM   #17
Mike Semeniuk
Mike Semeniuk's Avatar
Liked 6 Times in 2 Posts
deleted
Mike Semeniuk 632 GTMA
Mike Semeniuk is offline   Reply With Quote
Old 12-20-2013, 02:59 AM   #18
Tom Moock
Jerry, 283 SS chevelle 217 Hp, Impala 229 Hp, Chevy ll 236 Hp, Tom
Tom Moock 5704 STK
Old 12-20-2013, 09:29 AM   #19
Tom Meyer
I am not bitching we race the cars we like, I was just stirring the pot a little. The hard top chevy IIs with the current hp rating of 236 with a auto and current weight per hp is 11.99 that makes it a j car with a min weight of 2765 and if you can get a chevy II down to that you would be cheating too. In GT the hp on the 283s is 233. Tom
Old 12-20-2013, 02:54 PM   #20
JRyan
Both Tom's,
Of course you know that I know it isn't right. The Chevy II's were one of the first cars "kinda" factored way back in the early eighties when they set the index for SS/LA at 11.75. That was done because at the time the Nova's were somewhat dominant I guess. But it wasn't fair to get the lower index and then get factored hard too.
But ya gotta remember, we were all at 235 HP at one time. That's why we built the Olds. There was no way we could keep up with the 307's back then at 3460 lbs.. Now, even though the Olds is fast, at 217 HP I'm pretty sure the 4-door will run right with it..
Jerry
