Old 12-24-2013, 11:20 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default LT1 Rockers
I am planning to switch from stamped to roller rockers on my 98 350 LT1 stocker.
What is the rocker of choice and what other changes are required?
Also, Since the motor was originally built (Woodro) around 6-7 years ago, Any advances in camshaft technology I should be considering? The car is a stick, BTW.
Thanks and Merry Christmas to all!
John
John Nechiporchik is online now   Reply With Quote
Old 12-24-2013, 11:41 AM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: LT1 Rockers
John
If you passed Tech with the Stamped you will bounce with the RR's.
Stockers ratio is 1.47, RR are 1.5 and you can calculate from there.
Meaning you will need a new Cam for the RR.
Crane makes the GM Replacement 1.6RR but they also have the 1.5RR.
D
Old 12-24-2013, 12:10 PM   #3
Liked 1,874 Times in 422 Posts
Comp Cams has the best roller rocker for your car, they make a TRUE 1.5:1 Ultra Pro Magnum rocker specifically for Stock Eliminator, it is a special piece that Tim Cole developed for us. Yes, if your cam is 6-7 years old, or older, Tim and Billy probably have a new set of lobes for your application. There are also some new true race hydraulic roller lifters that are lighter, have less travel, run at near zero preload, and are capable of higher RPM while remaining stable and not floating.
Old 12-24-2013, 12:15 PM   #4
John Nechiporchik
Alan, Do you have a direct line contact for Tim or Billy at Comp?
Old 12-24-2013, 12:54 PM   #5
Well, you can reach Tim Cole after the first of the year. Just call the regular line and ask for him. Billy Godbold rarely talks on the phone, he's a lobe designer, he actually designs the cam lobes and deals with things like Spin-Tron testing, Tim runs the competition sales/support department.
Old 12-24-2013, 01:29 PM   #6
John Nechiporchik
Alan, Thanks. I'll track him down after the first.
Old 12-24-2013, 04:24 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
John
You have a PM with Tim's direct line @ Comp
You do need a cam and lifters as well as rockers.
Some stiff pushrods might help, too.
Adger Smith (Former SS)
Old 12-24-2013, 04:55 PM   #8
Gary Merrick
Gary Merrick's Avatar
Liked 196 Times in 29 Posts
John,
You have a PM..
Gary Merrick
Gary Merrick is offline   Reply With Quote
Old 12-24-2013, 04:59 PM   #9
Tony Goodman
Liked 18 Times in 4 Posts
Thumbs up Re: LT1 Rockers
John, Talk to Jeff Warren at Warren Racing Engines Ph# 910-592-6724. I've been extremely happy with the performance and service from them. Their a first class bunch!! Tony
Tony Goodman is offline   Reply With Quote
