Old 12-26-2013, 04:19 PM   #21
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Wheel shimmy
There are guys that say the Del-a-lum bushings are difficult to put in. Is that because the A-arms are a little off and that makes the holes in the bushings not concentric and that makes the shaft bind?
That's kinda the reason I was thinking about just replacing the whole arm. By the time I pay for shafts, bushings, ball joints and labor to press them in I'd be within 150 of their whole arm.
Ron Gusack is offline   Reply With Quote
Old 01-01-2014, 09:22 PM   #22
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Ron Gusack View Post
The Global West control arms have standard BJ's. Is that because they're built in such a way that long ones aren't needed?
The GW A arms are not specifically built for drag racing, unlike the TRZ tubular A arms. The GW arms are just aftermarket tubular replacements and are heavier than the stock A arms too.
As has been said, you need longer ball joints at a minimum, maybe a steering box and wheel alignment at ride height too.
BTW, while the Del Alum bushings from a number of aftermarket suppliers are trick, the same result can be accomplished with aftermarket poly graphite bushings which is what my former car had, using emery cloth, a drill and 2 zerk fittings...
