Old 01-05-2014, 10:44 AM   #131
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Econo Modified
Randy,
APBA already has a BB spec head, but the real challenge is to make all the different heads make close to the same hp per cu in. I think it would require head/manifold combinations to make things equal.
Adger Smith (Former SS)
Old 01-05-2014, 11:07 AM   #132
randy wilson
Liked 22 Times in 22 Posts
Yes, or simply have 2 different classes in the same class, and index them properly. That would be easier. Also, we could police ourselves with a racers board. Would be way more legit anyway.
don,t have one
Old 01-05-2014, 11:11 AM   #133
Ron E
Originally Posted by randy wilson View Post
What's the valve angle on the Ford head, and W2?
The 351N is 10°. W2's are 18°. There were some 15° W2's made,but are extremely rare.
oops, I missed your reply SSDiv6. But, on the possible head rule changes allowing a 14° Pro Action head in SS/CS. If the NHRA wants it to become a 1 brand class, that will do it.
Ron E is offline   Reply With Quote
Old 01-05-2014, 12:17 PM   #134
randy wilson
Well, if true, all GM cars in SS\CS prepare to change heads. For a small update price of, say $13,000 to $18,000 dollars with intakes, heads, valves, pistons, cams, etc. And then get ready for the next step. Allowing aluminum heads in. Then for the small fee of $15,000 you can compete again! Ain't it grand! Should work out REAL GOOD!!!
don,t have one
Old 01-05-2014, 12:24 PM   #135
FINESPLINE
FINESPLINE's Avatar
Makes you want to think about a spec engine with manual trans. Pick the body style and lbs/ci . EVERYONE who drives a stick knows the answer is in the can.
FINESPLINE is offline   Reply With Quote
Old 01-05-2014, 12:36 PM   #136
FINESPLINE
FINESPLINE's Avatar
Randy, If you really would like to keep it OLD SCHOOL and keep the word econo in this class, keep the the factory valve angles ( ie sbc 23 degree ). Inline wedge head only.
Old 01-05-2014, 12:52 PM   #137
randy wilson
ALL spec heads are factory valve angle. Chevy, 23 degree, Ford, 20 degree, Mopar, 18 degree. Already been handled. You do know we are saying a single disc clutch, min. diameter at 10.5 inch, and NO computers. The right clutch, pressure plate, and fylwheel will be the key. There would be no counter wts. allowed. Clutch would be required to be engaged on ALL shifts. Just saying.
don,t have one
Old 01-05-2014, 01:03 PM   #138
FINESPLINE
FINESPLINE's Avatar
All right, was not sure about clutchless trans and clutch setup. How about wheelbase limitations and finalizing a lbs/ ci. Starting to think of an old C/SM car !
Old 01-05-2014, 01:13 PM   #139
randy wilson
Ain't got that far yet, and actually ain't qualified to make the call on wheel base. Way over my pay grade! Ha!
don,t have one
Old 01-05-2014, 01:19 PM   #140
FINESPLINE
FINESPLINE's Avatar
One must realize that the NHRA and Ford are still doing their dance, for how long the music plays, I don't know.
