Old 01-06-2014, 09:17 AM   #11
Mike Fuller
Liked 203 Times in 80 Posts
Default Re: Rewiring a stocker
Do any of these kits have provisions for lights and panel lighting dimming?
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 01-06-2014, 12:37 PM   #12
black88coupe
black88coupe's Avatar
Liked 19 Times in 12 Posts
Yes
Mitch Beri- The Motor City
Old 01-06-2014, 12:46 PM   #13
Dallas Kelly
Liked 85 Times in 21 Posts
Spaghetti Menders has several options for wiring/switching panel and exterior lighting however I don't believe they offer a dimming feature for panel lights. Call Bob Lapp, he can offer a much better explanation than I. (815) 963-1005
Dallas Kelly is offline   Reply With Quote
Old 01-07-2014, 04:06 PM   #14
Chad Rhodes
Auto rod controls makes a nice setup with a remote relay panel. Or MSD smart wire
Chad Rhodes 2113 I/SA
Old 01-08-2014, 06:44 PM   #15
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
In the process of installing a K and R super duty wiring kit. this is a great kit that is easy to install and has a 3x3 diagram that anyone can read. K and R have great support from Kevin if having problems.
Bob Lasko
Old 01-08-2014, 07:57 PM   #16
BRIAN SEATE
K&R in my Super Stocker-fired right up, 2 seasons with no problems.
BRIAN SEATE is offline   Reply With Quote
Old 01-08-2014, 10:38 PM   #17
CMcAllister
Liked 920 Times in 259 Posts
Andy, if you're just looking for wire, terminals and connectors, and all of the related parts, pieces and hardware to put your own system together, check out Waytek at waytekwire.com.
It's frustrating trying to do electrical work with what's available at the local auto parts. I have dealt with these people for a long time.
Old 01-09-2014, 03:18 PM   #18
Stick Racing
Cole, It needs completely gutted and start over. It hasn't been touched since 1995.
Time for an upgrade.
_____________________________________
Andy Stone 1102 A/S 1112 SS/C
Stick Racing is offline   Reply With Quote
Old 01-11-2014, 02:16 PM   #19
Portatree Timing Systems
Portatree Timing Systems's Avatar
The Moroso Electronic Switch Panel (ESP) is pretty cool. It has a panel mount or roll bar mount switch board that connects to a main controller. The switches have lights on them that can be dimmed.
It is really powerful. It can turn your water pump and fan on/off based on engine temperature. It can also time out stuff in your car (so you don't have to worry about leaving stuff on after a run). It has warning lights too to let you know when oil pressure is low or a system in your car is failing. Definitely worth checking out. I don't think it is priced too much more than a K&R Switch. Portatree helped developed it and we run them in both of our stockers.
ID:	22616   Click image for larger version
www.portatree.com
Portatree Timing Systems is offline   Reply With Quote
