Old 01-12-2014, 05:01 PM   #81
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Suspension help
16-18 lbs, depending on the application ( GM, Ford)
Mark, I was interested in the GM 8 inch weight, thanks.
Old 01-12-2014, 05:09 PM   #82
Randy Guest
Liked 28 Times in 15 Posts
Thanks for the info. my car also has work on front control arms was a stick car all of its life so there is no toe out when it pulls the tires .
Randy Guest is offline   Reply With Quote
Old 01-12-2014, 05:10 PM   #83
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Randy the A arms on my former Chevelle are the original and stock it rolled off the line with in 1968.
Old 01-12-2014, 05:11 PM   #84
HP HUNTER
Originally Posted by 1320racer View Post
opinions are like as_ho_es, everyone has one but the truth is NO and the front end kit that Alf sells is priceless being that it fixes this issue.
I have those parts on the front of my car (Alfs). I have zero rise at 2500-2600 RPM. With a tighter ATI 5300 flash I did have lift at a much lower RPM, infact I think it was around 1800 RPM.
Old 01-12-2014, 05:12 PM   #85
1320racer
1320racer's Avatar
what parts, do tell us and FYI, my converter was the tighest ATI could build, flashing 53-5400 behind my 468 with ZERO front end rise at any RPM.
Old 01-12-2014, 06:12 PM   #86
Ed Wright
Ed Wright's Avatar
My Chevelle never had a rise problem after I put the A1 converter in it. Just had parts I modified myself. Toe out? Bump steer correction is something I assumed everybody did to any car. Not rocket science.
Ed Wright 4156 SS/JA
Old 01-12-2014, 06:13 PM   #87
HP HUNTER
ATI's tightest 8 inch converter flashes 5200-5300 behind my 10.5 compression, .560 lift flattappet 467 in a 27.80 baro. Weibe parts on the front of my car include: ball joint spacers, upper A arm bars/shafts.
Old 01-12-2014, 06:15 PM   #88
1320racer
1320racer's Avatar
posted an hour ago...
Posted 3 months ago on 10-16-2013, 08:28 PM
I dont run Alfs suspension
Old 01-12-2014, 06:23 PM   #89
HP HUNTER
Posted 10-16-2013, 08:28 PM
now claim you "have those parts" on the front of your car.
I was refering tp Alfs rear suspension, Ive done better with the TRRC rear suspension. I've always run Alfs front end parts from day one. Look for mid 1.2s from my Chevelle this year, on a 9 inch tire.
Old 01-12-2014, 06:29 PM   #90
1320racer
1320racer's Avatar
save you claims, lies and half truths for the naive and easily impressed.
BTW, Alf's front end kit does not include ball joint "spacers"
