Old 01-13-2014, 11:17 AM   #21
Stock726
Liked 39 Times in 10 Posts
Default Re: 03/04 346 camaro/firebird H.P. adjustment
Originally Posted by farmco r/sa View Post
under the nhra stock car classification for 2003 chevrolet section the change is under "GT factors." at the top, it is the yellow highlighted change dated 1/1/14. at the risk of sounding nieve what is a "GT factor" in stock???
This is because of the new rule that you can only run combinations that don't exist in classes that don't exist.....
Stock726 is offline   Reply With Quote
Old 01-13-2014, 12:12 PM   #22
farmco r/sa
Liked 147 Times in 54 Posts
interesting.... very interesting. more confused now..
farmco r/sa is offline   Reply With Quote
Old 01-13-2014, 12:29 PM   #23
goinbroke2
Liked 405 Times in 158 Posts
Exactly, that's why the 2013 mustang with the powerstroke is in SD/C and SD/CA. Personally I think the 400hp factory rating is a little high and it should actually be a SD/D or SD/DA combo.
edit: Just realised that SD is for naturally aspirated diesels, should of been SDT/C and SDT/CA
Last edited by goinbroke2; 01-13-2014 at 12:31 PM. Reason: Forgot the powerstroke is turbo'd
Old 01-13-2014, 12:30 PM   #24
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Upon my own research, I have gathered that the 405hp engine for GT was previously rated the same as the regular LS1, but the 405hp version has only one casting number for the head. This casting number is not the same as any other LS1 engine. Therefore this makes this combo different than the others. Is there 90hp more in this head? Absolutely not. However, it is listed with only one casting number for the head.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 01-13-2014, 12:44 PM   #25
farmco r/sa
excellent. it will be cool to see more diesels in stock. is there a VP accepted fuel yet? D10 ?
Old 01-13-2014, 01:43 PM   #26
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: 03/04 346 camaro/firebird H.P. adjustment
Ultra-low-sulfur diesel (ULSD)
Old 01-13-2014, 01:47 PM   #27
Ed Wright
Ed Wright's Avatar
Jimmy, isn't that the Vette LS6? 405 is the factory rating, I believe. If so, it should be stick-only, like the 1996 LT4 Vette engine. Different cam. The differences are moot for an S or SS engine. No reason to use it.
Ed Wright 4156 SS/JA
Old 01-13-2014, 03:00 PM   #28
Bobby DiDomenico
Liked 101 Times in 52 Posts
Is there a spec for Urea now?
Old 01-13-2014, 07:10 PM   #29
countrypuppy4865
Mr. Ed,
This is the Z06 engine. It should be manual only.
4865 E/SA '04 GTO
Old 01-13-2014, 07:27 PM   #30
Ed Wright
Ed Wright's Avatar
Mr. Ed,
No more than is different when you take away the cam and factory exhaust and air filter box, that contributed to the advertised 405 hp not much is left in race trim. Can't imagine anybody using one, can you?
