Old 01-13-2014, 01:59 PM   #11
Pvt Parts
Pvt Parts's Avatar
Default Re: Speaking of 16 volts.....
I do now. Didn't for four years. Then all that carnage in one weekend. Has anybody else checked their 16 volt charger for AC voltage? When an automotive alternator does that it's because the rectifier failed. That converts AC to DC. Not sure about a charger.
MSD replaced that box, FAST fixed both ECUs. Kinda pricey weekend.
I turned the master cut off switch off while Slate's ECU & my back up MSD box was in it. Have not had another race, but will do that from now on .
Scared of that charger now.
Ed,
I've popped the MSD high end chip a couple of times when charging with the main switch on. Only happened when the charger to the post connection was "sparked" by someone plugging in the charger first or accidentally knocking it off while charging.
Old 01-13-2014, 02:07 PM   #12
Ed Wright
Ed Wright's Avatar
Ian, I have mine wired right now with a plug under the hood for a 12 volt cool-down battery. (thanks Mike Edwards!) I guess I need to look into doing something there. Right now I have a four pin Weather Pack connector I unplug the fans & water pump from the car, and connect to the cool down battery. Might need a six pin, and not put anything in the car side of two going to the ECU so it won't back feed.
Ed Wright 4156 SS/JA
Old 01-13-2014, 04:33 PM   #13
Ed Wright
Ed Wright's Avatar
Scott, I have the female plugs like found on a welder recessed into the left rear fender. I never plug or unplug the cables with the charger turned on. No crew to "help ", most always just me. Only have to look in the mirror to find the guy that messed up. LOL
I think high AC volts got everything. Won't happen again. A couple of guys were going to check their 16 volt chargers for AC, but I have not heard back. I know a leaky rectifier in a street car alternator gives the computer fits.
Old 01-13-2014, 04:53 PM   #14
Ed Wright
Ed Wright's Avatar
Originally Posted by Jim Hanig View Post
Ed there is a place in Ok city that fix mine 50.00or 60.00 dollars a couple of years ago been good as new since.
Jim, do you remember the name of the place?
Thanks!
Old 01-13-2014, 05:13 PM   #15
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
i am assuming i want feed back to the modules - i want to check my race pak between runs, and make adjustments to the MSD (shift points, launch rpm, timing et) - i am bringing this up, more to get your opinion to make sure i am not missing something here, as i haven't actually hooked the batteries up to test what i have installed yet!
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 01-13-2014, 06:06 PM   #16
Ed Wright
Ed Wright's Avatar
Yes, Ian, I messed my stuff up downloading my FAST internal data logger, and killed an MSD box also, doing that with the battery charger going. My charger shows 19.2 volts DC. I think the 40 volts AC is what hurt things. Got away with this for four years, then it took a bite out of my rear at the Noble, OK LODRS at the end of the season. Never checked for AC voltage before this. Have not heard back from anybody yet about their 16 volt chargers putting out AC. Kinda think they don't.
Old 01-14-2014, 01:53 AM   #17
Jim Hanig
Liked 99 Times in 49 Posts
Thanks!
Not off the top of my head, but it seems like tubo start sent me to them.I will see if i can find the ticket and let you know
Old 01-14-2014, 11:23 AM   #18
Ed Wright
Ed Wright's Avatar
Thanks Jim!
OKC is not far from me.
Old 01-16-2014, 07:05 PM   #19
Jim Hanig
Thanks Jim!
Ed, Quick Charge Corp 1032 S.W. 22nd ST Okla city 1800 658-2841 or 405-632-5667 Hope this helps
Old 01-16-2014, 07:53 PM   #20
Ed Wright
Ed Wright's Avatar
Thanks Jim! This is a big help!
