Liked 14 Times in 8 Posts
Hi
what type bushing ball joint etc is the best, im looking to refresh my stuff thanks for you help |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
I don't know if it's the best but it's what we use.
Global west bushings and extended ball joints. They sell it in kit form
Marty Rinehart Jr 1125 SS STK SG SC SST |
Liked 33 Times in 17 Posts
Matt,
Check out Howe Racing Enterprises. That have extended ball joints that go up to .9 long. |
Liked 799 Times in 236 Posts
Mat, I went with Energy Suspension urethane control arm bushings, Moog #K5250 offset control arm shafts and standard Moog replacement ball joints.
Afco and ProForged make low friction extended upper ball joints. QA-1 has standard length low friction ball joints that can be serviced. -Al
"That'll never work....." |
Liked 319 Times in 82 Posts
Afco steel bushings and there low friction ball joints, the Afco tops can be ordered .5 longer.
Liked 55 Times in 26 Posts
I just did what J&S posted and it made my car totally different! It was an easy install, car has a ton of front end travel now and drives like a dream
Thanks for the help guys!
Liked 5 Times in 3 Posts
Are the replacement bushings roller bearing or something like that ? When you say steel bushings does this mean its steel to steel ,no bushing material ? The longer Ball joints are for reducing camber change? thanks
The global west bushings are aluminum and derlin I believe and the Afco's are solid steel with grease fittings.
Liked 6 Times in 3 Posts
What is the point of the longer ball joints?
