Old 01-09-2014, 07:56 PM   #191
Ed Wright
Ed Wright's Avatar
Default Re: Econo Modified
Originally Posted by Bob Lasko View Post
Ed,
When I started to get serious about running in NHRA back in the mid 70's, I ran in C/SM in Modified Eliminator. I started with a 67 Nova, a real L79 SS car. I put a 305 together with the turbo head at first with an m22 4-speed with a 12 bolt rear out of a Camaro. Then after breaking the Trans a number of times went to a hemi 4-speed that I got from Toni File. We ran on 10 inch tires with frame connectors. Ran with the likes of Charlie Daniels. Just before the split to super Stock I went to the 461 heads. Those were the days that we had a real lot of fun, 10,000 rpm. Then I got divorced and quit racing. Then in 1988 came back out with the Nova with the big tires, 3 years later the Camaro that I am still running.
Bob Lasko
Bob, I did too. Had a '69 Camaro, running Modified here in Div 4. Took the points lead about mid season, lost to Bob Vanderley at the last race. Ended up second.
We weren't allowed the turbo heads in C/SM then (Don't remember if they were allowed in B/SM) Had to be production car heads, in C, those never came on a car. I had Turbo heads on my 317" for IHRA, where they were legal. For sure faster than the 461X heads. I did the turbo heads myself. My fastest NHRA heads were from Lee Shepard. Had three sets from different shops. Garley Daniels put me onto running 2" headers. Also an Air Speed Engineering intake manifold. Garley is a great guy. I never could run with him. Very fast guy.
It was 10.5" tires we were allowed. Also a 750 carb. IHRA allowed an 850, turbo heads and 11.5" tires. Even my IHRA 317" liked the. 750 better.
Fun cars.
Ed Wright 4156 SS/JA
Old 01-16-2014, 02:24 PM   #192
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Let's hear some more stories
Mike Taylor 3601
Old 01-16-2014, 04:35 PM   #193
Dick Butler
Liked 32 Times in 19 Posts
Are there any years left in any of us to support this class? Most of us are out of racing a couple of years. Do we have a driver, son or daughter to carry on this idea? My daughter would LOVE to jump into one of these cars if we could get it going. Many 50s guys on here who are interested?
Old 01-16-2014, 04:44 PM   #194
randy wilson
Liked 22 Times in 22 Posts
I would try to drive at first, but I have not driven since 2005. But my son, now 28, is one of the best. He drove the cobalt at Bethany one night, (Steve let him after we were done that night) and did fine. He also drove about every weekend in a car that needed a driver, because all points there went with the car. So he has about fifty passes under his belt, and was consistently in the low 4's on reaction, on a pro tree.
don,t have one
Old 01-16-2014, 06:43 PM   #195
Todd Bailey
Liked 33 Times in 17 Posts
Dick and Randy,
I think you would be VERY surprised at the amount of people who would do this. I am in the process of building a Stock Eliminator Nova but I also have a '63 Corvette hardtop that already has the narrowed frame rails and Dana. Needs MUCH work but I would do this. I am in my early fifties and grew up watching Modified Eliminator. Was just TOO young to do it back then. As someone stated on this post, the cars would have to debut as a racing series at, I believe, divisionals before NHRA would even begin to look at it. I was mentioning this to my engine builder and the first thing out of his mouth was "use a spec head". Where have we heard this before?????
Todd Bailey is online now   Reply With Quote
Old 01-16-2014, 07:52 PM   #196
randy wilson
Todd, glad to hear I ain't the only idiot that thinks this would work. I also have Chris Paget of Comp Cams, Al Parker, of Parker engines, (he builds a lot of spec sprints), and the editor of Drag Illustrated, Wyatt Halden interested, and said he would put out a huge article on it if it evolved into a class. Does anyone remember the Midwest Drag Magazine that promoted an econo class dragster\altered with flat tops, and hydraulic cams? It never got off the ground for three reasons. One, they never gave it a real chance, two, any iron head, that I think you could modify, and three, no one even knew it existed. We damn sure don't want to make the same mistakes. Anyone that wants to slam this as eventually an out of control class, needs to understand there would be NO GREY AREA! The reason their econo class never took off was the unlimited selection, and modifications allowed to the head. In that case, yes, comp guys would rule. The head is the key, and the one truly limiting factor.
don,t have one
Old 01-16-2014, 08:13 PM   #197
Dick Butler
Randy, please explain the Cam and spring specs. Any rev kit rules?
Any Div 3 interested parties?
Old 01-16-2014, 09:59 PM   #198
randy wilson
We never had a cam spec in spec, which was our top class. But we had a .500 lift max in stock, .600 inch max in modified stock, and stock option. It was easy to check with a dial indicator at the valve. The Brodix spec head for Ford, Chevy, and Mopar will only except 1.55 springs, nothing larger. I think a .700 lift max at the valve will save money on valve train in spec. I found no performance difference with a cam basically in that range with a spring at 350# on the seat, and 850# over the nose, then with a spring at 285# on the seat, and 675# over the nose. So, I think it would take a lot of expense out of the valve train. Now then, if you allow unlimited lift, however, it would come into play. We were successful in turning 9,600 rpm with the lighter springs, you just had to stay on top of them. I don't care either way on rev kits. I won't use one, but I say go for it. There is less HP with one installed, so I don't think it's an issue.
don,t have one
Old 01-16-2014, 11:02 PM   #199
Ed Wright
Ed Wright's Avatar
Spec heads would be the way to go.
Old 01-17-2014, 09:28 AM   #200
Mike Taylor 3601
Dick,
I'm in div 3,and 46 years old, modified is what I wanted to race,I was trying to get there when IHRA still had it,but did'nt make it in time,sold that car.
The spec head would put it within reach for me,alot of exotic heads are'nt that expensive by theirselves,but by the time you get everything to go with them the price goes way up,then a year or two later,there's a better setup you need to compete.
I maybe able to get my hands on borrowed car,and put spec head engine together,but would take me some time.
Mike Taylor 3601
