Old 01-19-2014, 11:22 AM   #1
ollucky
Default Help car drops 700 rpm when going from neutral to first gear
New combination 406.
Car drops 700 rpm when going from neutral to first gear and will eventually die. It gets worse when the car is at operating temp. Ignition?
Please Help.
ollucky is offline   Reply With Quote
Old 01-19-2014, 11:58 AM   #2
Liked 1,952 Times in 439 Posts
Default Re: Help car drops 700 rpm when going from neutral to first
Sounds a lot more like carburetor than ignition. Quickest way to find out is to swap another on it. Also, check the power valve(s) if so equipped.
Old 01-19-2014, 12:02 PM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
either lock out the distributor or recurve it so it has ~ 20 degrees initial and 16-18 degrees mechanical advance. Easy to do with an MSD distributor.
Old 01-19-2014, 12:02 PM   #4
Adger Smith
Liked 880 Times in 311 Posts
Holley carb?
Adger Smith (Former SS)
Old 01-19-2014, 12:03 PM   #5
ollucky
Also very hard to start at operating temp!
Little M Block 14:1 cam @ 50 278 intake 290 exhaust 111 lobe separation AFR 210's 5800 stall 750 carb that flows 920.
Old 01-19-2014, 12:05 PM   #6
1320racer
1320racer's Avatar
way too big cam and not enough stall but that's not your question.
Old 01-19-2014, 12:07 PM   #7
ollucky
Distributor locked.
Old 01-19-2014, 12:10 PM   #8
ollucky
Originally Posted by Adger Smith View Post
Holley carb?
Yes
Old 01-19-2014, 12:10 PM   #9
1320racer
1320racer's Avatar
how's the carb setup/baselined...how/where are the floats set, same question for transfer slots? What is the idle set at? Also how much fuel pressure?
Old 01-19-2014, 12:14 PM   #10
ollucky
how's the carb setup/baselined...how/where are the floats set, same question for transfer slots? Also how much fuel pressure?
Jet size 82 all the way around float level fine. transfer slot I don't know. how do I check?
