Old 01-19-2014, 01:40 PM   #21
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Help car drops 700 rpm when going from neutral to first
get the carb off yet?
Old 01-19-2014, 02:04 PM   #22
ollucky
Please Call Me 210 533 8058 Raul
ollucky is offline   Reply With Quote
Old 01-19-2014, 03:06 PM   #23
ollucky
Originally Posted by SSDart View Post
All four? How big are the holes? If the holes are too big they can create issues also
.165 bore have use this carburetor for years and have never had this problem.
Old 01-19-2014, 03:17 PM   #24
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
There is the key. What has been done/changed since the last time it ran properly? You stated this is a new combination...did you by any chance add/change any timing related or ignition components?
Rich Taylor
I/SA - 321
Old 01-19-2014, 03:52 PM   #25
1320racer
1320racer's Avatar
Raul, making any headway?
Old 01-19-2014, 07:07 PM   #26
ollucky
1320 Racer ... Please send me your number and I'll call you. thanks
Raul
Old 01-19-2014, 07:49 PM   #27
ollucky
Just engine combo long block? Went from a 355 to a 406. Same Heads Intake and Carb for the last 15 years.
Old 01-19-2014, 08:08 PM   #28
HandOverFist
My point was carb's don't just go bad/quit working overnight. Unless it has sit idle for a very long time with old fuel I would tend to look elsewhere first. Someone suggested earlier trying another carb for effect...way less time consuming and a quick way to eliminate one potential area.
Rich Taylor
I/SA - 321
Old 01-20-2014, 09:30 PM   #29
Mike Jones
Liked 684 Times in 289 Posts
New combination 406.
Car drops 700 rpm when going from neutral to first gear and will eventually die. It gets worse when the car is at operating temp. Ignition?
Please Help.
I`m sure you`ve already looked for vacuum leaks....
Old 01-21-2014, 10:53 AM   #30
Bimbo Jones
I had the same issue with a 750dp on my wagon. It turned out to be the transfer slot on the secondary's. I bought an adjustable 1 to 1 linkage for the carb. While it look to be adjusted correctly on the bench but when I attached the quick disconnect linkage to the carb it pulled the secondary butterflies just enough to cover the transfer slot. I put the original bent metal part back on problem was corrected. Good luck.
Bimbo Jones is offline   Reply With Quote
