Old 02-08-2014, 07:13 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default TH-350 Speedometer Plug Size
What's the best way to plug the speedometer cable hole on a TH-350? Use an old cable setup or what size plug?
brian schuetta is offline   Reply With Quote
Old 02-08-2014, 08:59 PM   #2
Liked 5,131 Times in 1,956 Posts
Default Re: TH-350 Speedometer Plug Size
There is no fractional fit for the drive, which is about 2.075.You have to go to 2.100 and run it on a belt sander.
I usually use a rubber expandable plug ..Just install it dry. I mean brake clean dry!
Old 02-08-2014, 10:30 PM   #3
brian schuetta
Mark
I knew you would know the diameter but where the hell would I find that plug? I'm going to the junk yard tomorrow to finish stripping a 305 short block. What would I need from a TH-350 to plug the hole properly?
Old 02-08-2014, 10:39 PM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
If you have an old head I would just use it...has an o-ring if I remember right.
Rich Taylor
I/SA - 321
Old 02-09-2014, 10:52 AM   #5
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
how about a metric freeze plug?
I'm assuming it's the large speedo adapter rather than the small "bullet"....
Old 02-09-2014, 11:04 AM   #6
HandOverFist
Depending on the size you might consider a boat/livewell type expanding plug.
Rich Taylor
I/SA - 321
Old 02-09-2014, 11:13 AM   #7
Rick Blake
Rick Blake's Avatar
Sonnax Transmission Parts
Part # 35922-01K. TH350 Speedometer Hole Plug. During high performance rebuilds, the speedometer gear is often removed and replaced by a freeze plug. However, in addition to being used for driving the speedometer, the gear is also critical to lubricating the rear output shaft bushing. This new speedo plug supports the speedometer gear and allows lube to flow as the original design intended. The gear shaft has to be cut to 1.320" long. Cost $24.00
http://www.transmissioncenter.net/So...uper_Store.htm
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 02-09-2014, 11:18 AM   #8
HandOverFist
That being the case then the original stock head would seem to be the way to go after all.
Rich Taylor
I/SA - 321
Old 02-09-2014, 11:30 AM   #9
Dragsinger
Liked 99 Times in 60 Posts
I will need solid engineering proof about the statement "helps lube rear bushing"
Just consider the units in service with speedo adapter hole plugged yet they experience normal rear bushing service life.
Larry Woodfin 471W
Old 02-09-2014, 12:06 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The spinning governor provided the needed lube for the rear bushing. This was true for the 700-R4 also. When the transmissions were redesigned to the "e" versions, a hole was drilled that pee'd fluid back to lube the bushing.
