#21 |
Liked 22 Times in 22 Posts
Bill, I think they used Hardbloc, but not sure. Been 10 years ago. There may very well be a way to do it right. I know lots of people swear by it, and some of them are hitters. I'm just giving my little bit of experience with it. On one .90 over 283, (I know that's a weird bore size) it never stopped moving around, even after 4 hones. It was an SS\CS 287, north of 600 HP with iron bowties.
don,t have one |
#22 |
Liked 237 Times in 126 Posts
Thanks for all the replies and suggestions.
I have read that the nickel content is not higher but the casting is a bit thicker and the mains are wider. Stronger than stock but not BOSS strong. It's been mag and pressure tested and the decks checked. I need to see the documents for that as well as photos of the block numbers before I move ahead. My other option is to build using the current block which overheated and locked up on the way home from the purchase of the car. Read: No option. Dale
#23 |
Liked 99 Times in 49 Posts
Save your money and buy a svo or boss , You will save money in the end.
#24 | |
Liked 163 Times in 53 Posts
As plentiful as the blocks are do not waste the money on a 50 over block...
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA Last edited by Stephen & Horace Johnson; 02-09-2014 at 01:21 PM. |
#25 |
Liked 28 Times in 1 Post
Dale, there is a B-50 “sportsman” block that Ford was making that was a “new” casting of the “mexican” block. I put about 100 passes on this type of block turning 9500 rpm around 580 hp without block fill and without a stud girdle. Just make sure and have quality machine work done and use ARP studs throughout. As soon as I could afford it I went to the “Boss Block”. There is a WORLD of difference between these blocks. The boss block is around 20 pounds heavier than the B-50 block I was using. There is a TON more material in cylinder wall, lifter bore area, cam tunnel, deck and mains. = more HP
The machining cost is the same on a production block and boss block. The Boss block is REALLY “cheap” at $1800.00 Figure a Used block, machine work and then if you are crazy enough to try and use hard block, dealing with the overheating from the block filling, ring seal etc, believe me go with the best parts first. You are going to end up buying it in the future anyway. Whatever you do, do not bore over 0.040” in a production block, test the wall thickness with US, the production blocks are super thin. Happy building.
Ashton Hudson SS/CS 4373 |
#26 | |
Liked 100 Times in 45 Posts
Former NHRA #1945 Former IHRA #1945 T/SA |
#27 |
Liked 1,595 Times in 583 Posts
#28 |
Guest
Posts: n/a
Delete
