Old 02-07-2014, 03:10 PM   #1
Doug Domm
Liked 84 Times in 21 Posts
Default VP to Sunoco reference
Is there a VP to Sunoco equivalency reference chart anywhere and typical tune changes between fuels?
Doug Domm is online now   Reply With Quote
Old 02-07-2014, 06:17 PM   #2
VanPelt
VanPelt's Avatar
Default Re: VP to Sunoco reference
http://www.smithtex.com/racing/fuelcomp.html
VanPelt is offline   Reply With Quote
Old 02-08-2014, 12:39 AM   #3
Doug Domm
Excellent reference chart. Thank you
Old 02-11-2014, 09:24 AM   #4
njk53
Is VP C-10 Leaded or Unleaded?
Nelson Kowal
Stock 345
Old 02-11-2014, 09:35 AM   #5
Rsmith38
Liked 28 Times in 15 Posts
C-10 is unleaded. (Now C-9 also unleaded)
Rsmith38 is offline   Reply With Quote
Old 02-12-2014, 10:44 AM   #6
njk53
Is there a leaded fuel with a lower octane (100 or less) out there that is NHRA Approved?
Nelson Kowal
Stock 345
Old 02-12-2014, 03:58 PM   #7
jmarkaudio
What you want to pay attention to is the SG and RVP of the different fuels. Similar specs on both will usually need similar jetting and perform close. If either deviate you will likely need to make changes. As far as lower octane than 100, what are you looking to lower octane for?
jmarkaudio is offline   Reply With Quote
Old 02-13-2014, 09:25 AM   #8
njk53
I have a 9:25.1 Compression Ratio Motor. It would run much more efficiently on a lower octane fuel than 110.
Nelson Kowal
Stock 345
Old 02-13-2014, 12:18 PM   #9
Mike Croley
The best way to get the specs for race fuel comparisons is from each manufacturers web site. The specs change fairly often. The above referenced chart is out of date I believe. You'll want to pay close attention to the Motor Octane, and the RVP number.
Most companies also have a crossover on their web sites to make it easier to switch between brands.
And race gas for lower compression engines is available from a number of sources. Sunoco, Renegade, VP all make race gas for lower CR engines.
Mike Croley is offline   Reply With Quote
Old 02-13-2014, 12:35 PM   #10
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: VP to Sunoco reference
Mike,
Thanks, for the info ... What low CR gas is approved for NHRA /IHRA & what would you recommend for an 8 to 1 ???
Dave Ribeiro 1033 STK
