Old 02-15-2014, 07:45 PM   #1
Weekend Racer
Question low volume oil pump
I plan to use schumann low volume ,low pressure oïl pump in my chevy 350 SS/HA.The main bearing clearance are at .0029 +/1 .0001
. What oïl pressure I can expect?.
Thank!
Weekend Racer is offline   Reply With Quote
Old 02-15-2014, 07:56 PM   #2
Liked 1,893 Times in 423 Posts
Default Re: low volume oil pump
So, you're running a -10% volume pump and what amounts to 0.003" on the mains? What is your clearance on the rods? What oil?
Old 02-15-2014, 09:37 PM   #3
Weekend Racer
Sorry,you should read main bearing clearance are at .0029 +/- .0001. The rod clearance are at .0026. +/- .0001. The rod side clearance are at .014. 15W 40 oïl .
Thank!
Old 02-15-2014, 09:48 PM   #4
Ed Wright
Ed Wright's Avatar
That's a lot of oil clearance for a low volume pump, isn't it?
Which rod journals?
Ed Wright 4156 SS/JA
Old 02-15-2014, 10:09 PM   #5
Weekend Racer
rod journal are at 2.0995
Old 02-15-2014, 10:29 PM   #6
carl hinkson
Liked 18 Times in 10 Posts
What are you using to come up with that clearance?
carl hinkson is offline   Reply With Quote
Old 02-15-2014, 11:10 PM   #7
Thank!
So, for all intents and purposes, that's about 0.003" on the mains, and 0.0025" on the rods.
Too much clearance for a -10% volume pump. And 15W40 is not really a good oil choice, either. You'll have about 10 psi hot at an idle of 800 RPM. And maybe 50 psi at 6000-7000 RPM.
Old 02-15-2014, 11:11 PM   #8
Weekend Racer
Block is dart shp pro block, Crank is Gm 1184, rod are crower ml 93005.
Old 02-16-2014, 10:07 AM   #9
Ed Wright
Ed Wright's Avatar
I think that is too much period.
Old 02-17-2014, 12:56 PM   #10
Jim Hanig
Liked 99 Times in 49 Posts
Ed what would you have for rod $main clearance
