Old 02-15-2014, 01:03 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 774 Times in 142 Posts
Default VP fuel. $$$$$$ and Corrosion
Folks, I am a bit disgruntled with the VP fuel situation. For one, the price has just gotten totally out of hand. And secondly, are other folks seeing the amount of corrosion in the chambers, exhaust ports and header ID ?? I realize regarding the header ID, most folks probably have the ID jethot/nitroplate coated..mine are only coated on the outside. But I am more concerned about the internal corrosion.. There is even a remnant of what appears to be some corrosion on the cylinder walls... I am stepping it up this year with a new block, and mega $$$ metric rings, and the last thing I want is to have corrosion issues wiping out those rings..
I can see oxygenated fuels doing this, but C-11 ??
Good alternatives to C-11 in a low compression combo ???
Any thoughts would be appreciated.
Kevin
Old 02-15-2014, 02:25 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: VP fuel. $$$$$$ and Corrosion
I have not seen that. I run C11, and my headers are just painted.
Ed Wright 4156 SS/JA
Old 02-15-2014, 02:32 PM   #3
Liked 1,903 Times in 427 Posts
Fuel choice will not likely change the corrosion rate on the inside of your headers. And if you had them coated on the outside only, you're asking for it.
That being said, we once had a problem with fuel corrosion in a carburetor. We had loaned the car to someone else, so there is a question as to whether it was what he had or what we had. Either way, some one's racing gasoline literally ate the inside of both float bowls on our prized Clark Holroyd 3310 carburetor, filling them and the rest of the carburetor with a nasty white paste.
To say that having a fuel related problem not only damage an excellent carburetor, but also cost us a round of class and then the first round of eliminations, while it damned near destroyed a new engine by filling a cylinder full of gasoline after the car was parked, pissed me off, would be the understatement of the decade.
Old 02-15-2014, 02:53 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
If you have iron heads and I assume you do...
When your done racing......hold the carb wide open and spray WD-40 in the engine while you crank it over and stuff rags or get caps for the headers.
You can also pour Marvel Mystery Oil in it with it running until it stalls or ATF.....or just pour it in and crank the engine.
Yea it smokes next time you start it and you might need to change spark plugs more often but it is the best way to protect an iron headed engine.
Open headers let air in and causes rust around exhaust seats and the backs of valves...
Rich Biebel
S/C 1479
Stock 147R
Old 02-15-2014, 03:22 PM   #5
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Just an opinion,but this is yet another reason why I prefer Sunoco.
Old 02-15-2014, 03:43 PM   #6
Dave Ribeiro
Liked 56 Times in 27 Posts
Cool Re: VP fuel. $$$$$$ and Corrosion
442OLDS,
What kind of Sunoco fuel do you run & what's your CR ? I am still looking for VP 110 replacement with less octane 93-100 range , that's NHRA/IHRA approved ??? thanks...
Dave Ribeiro 1033 STK
Old 02-15-2014, 06:32 PM   #7
mopacltd
Liked 124 Times in 44 Posts
I m pretty sure he is running the 110 purple Sunoco with stock eliminator compression.
mopacltd is offline   Reply With Quote
Old 02-16-2014, 02:08 PM   #8
ken robinson
Liked 224 Times in 87 Posts
I ran sunoco purple in the 350 combo never any problems alway passed fuel check
Old 02-16-2014, 06:22 PM   #9
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
I do a procedure similar to Rich, with VP fuel. I have previously seen the cylinder heads, cylinder walls, valves and throttle blades rust.
Patric Fox is offline   Reply With Quote
Old 02-16-2014, 08:29 PM   #10
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Years ago a company made plastic spark plugs that were filled with desiccant, {silica gel}
Had no problems after using them, only needed to stick them in the oven when removed.
Dan Dvorak also sold header plugs filled the same way. Both took care of all the problems, all you had to do is cap the carb. Buy some silica and improvise, make your own.
Bob Pagano A/SA
