Old 02-20-2014, 12:56 PM   #31
Harry 6674
Default Re: Header Retention Rule Revision
Originally Posted by Randall Klein View Post
Look Brett, I admire your history and passion for the sport, however I find your veiled historical snarky comments a little tiring....and not the Boertman comment alone either
At Topeka got ran over by a kid on a mini scooter, at Denver, in the restricted area under the tower, got a rock off a burnout just above the eye, and on and on over 25 years....stuff happens, and if you've been around for awhile there's plenty of danger at the strip
A nanny state tries to insulate all from any possible consequences....maybe those worried about any potential harm should take up curling...oh wait! There was an injury in curling...maybe just stay in bed
I would bet more fans and racers have been injured by quads,scooters and golf carts in the pits one one year then injured by loose collectors since organized drag racing began.
Harry 6674 is offline   Reply With Quote
Old 02-20-2014, 01:05 PM   #32
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
My tubes and collectors have been bolted for 10 years now to the frame. Never an issue.
Bob Bender 144 O/SA
Old 02-20-2014, 01:42 PM   #33
Chuck Garey
Liked 10 Times in 7 Posts
I guess I am missing something, in the first part it is stated they must be securely fastened with bolts so IS my OEM tab/bolted connection good or not?
Chuck Garey is offline   Reply With Quote
Old 02-20-2014, 01:53 PM   #34
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Originally Posted by Bob Gullett View Post
The way I read it is all you need is a exhaust hangar and a muffler clamp per collector. Attach the hangar to the body or frame with a muffler clamp attached to the collector. $10-20 worth of parts.
I kind of read it that way too,except there probably will be another rule amendment that the hangar and muffler clamp have to be NHRA accepted.The Napa version may not qualify.LOL
Old 02-20-2014, 02:18 PM   #35
buzzinhalfdozen
Liked 11 Times in 8 Posts
Excellent question...I've wondered since they state half in stitch welds (but doesn't state welding collector to primary tubes) why doesn't a tab on each tube using fasteners qualify. You still have the minimum weld area and you're still using fasteners and it still requires "tools" to remove. Think I'll wait this out as long as possible and see what the FINAL decision is.
Joe Buchanan SS/BX 3117
Old 02-20-2014, 02:20 PM   #36
Chad Rhodes
looks like that might be applying to cars with full exhaust only
Chad Rhodes 2113 I/SA
Old 02-20-2014, 02:38 PM   #37
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
I agree. If guys would just use steel self locking nuts (not fiber locks) and keep an eye on them and the welds on the tabs, there would be no problems. Just start to bar the guys that loose them from running any more events, they would pay more attention.
And, I bet Jack used a real good grade coat hanger. LOL
Or just use safety wire with drilled bolts? Seems like another easy solution.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 02-20-2014, 02:56 PM   #38
Ed Wright
Ed Wright's Avatar
That too.
Ed Wright 4156 SS/JA
Old 02-20-2014, 03:03 PM   #39
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Chad you are exactly right. . I got an email and I made a phone call...
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 02-20-2014, 03:22 PM   #40
Chad Rhodes
NHRA needs to hire a technical writer that a) knows what they are writing about, b) English is their first language, because that rule revision is very poorly worded
