Old 02-23-2014, 07:23 PM   #1
Mike Fuller
Liked 203 Times in 80 Posts
Default This does not add up!
CHANDLER, Ariz. - Results of round 4 eliminations in Stock Eliminator at the NHRA Mello Yello Drag Racing Series, 30th annual CARQUEST Auto Parts NHRA Nationals:
Car#-Driver(Opp'nt)-RT-----ET-- Speed-----Car#-Driver(Opp'nt)-RT-----ET-- Speed
5035 Keith Lynch 72 Leo Glasbrenner
E4 0.023 10.113 117.17 ****WINNER**** 0.061 10.591 123.32
A/SA Dial: 10.05 (+/-): 0.063 C/SA Dial: 10.51 (+/-): 0.081
Prior rounds:
E3 (J Cooper ) 0.036 10.202 -0.798 (T Kadar ) 0.020 10.568 0.008
E2 (D Machael ) 0.100 10.073 -0.927 (P Biondo ) 0.026 10.535 -0.005
E1 (B Burton ) 0.010 10.311 0.031 (N LaPointe ) 0.011 10.590 0.070
Qualified: #29 10.321 -0.679 #8 10.509 -0.891
Weather conditions: air temperature 74 degrees, relative humidity 24 percent, barometer 28.79 inches, adjusted altitude 2,628 feet, track temperature 108 degrees
Keith has the better light and runs closer to his dial and losses ???
I guess there is no rerun's this far into the program.
Mike Fuller 396 STK
3961 SS
Mike Fuller is online now   Reply With Quote
Old 02-23-2014, 07:39 PM   #2
Jeremy1374
Jeremy1374's Avatar
Default Re: This does not add up!
I saw this too and thought the same thing. All my dad and I could surmise is lynch gave up the stripe. Or there was a "problem". Not the first time I've seen the same thing.
Jeremy Erny
Jeremy1374 is offline   Reply With Quote
Old 02-23-2014, 07:40 PM   #3
WDCreech
WDCreech's Avatar
I doubt if anyone will shed some light (explain) on how this happened. The clocks aren't supposed to lie!
1964 GTO 2750# 606" IA Pontiac 8.2550@164.17-1/4 1.1981-60" 5.2901@131.97-1/8
WDCreech is offline   Reply With Quote
Old 02-23-2014, 07:44 PM   #4
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
My guess is Leo's dial in is mistyped on DRC. His dial in should be 10.57 which would make the numbers add up and show his .082 package crossing .004 in front of Keith Lynch's .086 package.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 02-23-2014, 07:50 PM   #5
Jeremy1374
Jeremy1374's Avatar
You're correct. The summary of the eliminator corrected his dial.
Jeremy Erny
Old 02-23-2014, 08:09 PM   #6
BobOrme
If a clock operator enters an incorrect dial, then corrects it without reentering both cars, the dial change is not picked up through the data feed. If the reporter doesn't notice the change and manually enter the correct dial, you get what you saw there. The data feed still flags the correct winner, but the numbers don't add up.
BobOrme is offline   Reply With Quote
Old 02-23-2014, 08:18 PM   #7
Mike Fuller
Thanks for the explanation Bob.
Mike Fuller 396 STK
3961 SS
Old 02-23-2014, 08:38 PM   #8
Tony Janes
The dial in was 10.57
Tony Janes 7941 STK, SS
