Old 02-27-2014, 09:52 AM   #81
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Default Re: Header Retention Rule Revision
Originally Posted by Dan Fletcher View Post
I think this has been the most overblown deal I've ever seen. It's not like they're saying you have to buy new ones every 2 years, it's a one time deal. Mufflers were worth fighting about, this is not, IMO.
Very well said.....
Mack Reeves
2377 STOCK & SUPER STOCK
Old 02-27-2014, 10:06 AM   #82
Jeff Teuton
Liked 325 Times in 50 Posts
It is a little muddy. My understanding all along was the tether itself should be minimum 1/8 SS cable, and a loop of some kind on each end secured on a primary tube and the collector with a T-Clamp (Aircraft Clamp and several other names). Or you could have used a tether with a loop on each end, the collector end secured by the T-Clamp and you could bolt the other end to the frame with a bolt thru the frame. I have sent this to NHRA thru SRAC for clarification. Sometime what they mean and what gets printed is different. There seems to be confusion on the multi piece exhaust that run all over the car like plumbing pipe which I think some Fords got.
Jeff Teuton 4022 STK
Old 02-27-2014, 10:36 AM   #83
Signman
Liked 269 Times in 99 Posts
NHRA is requiring 2 methods of retention if you headers have removable collectors. Conventional method plus one of 3 options.
Old 02-27-2014, 11:47 AM   #84
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
Mine is good !!!!
Bob Bender 144 O/SA
Old 02-27-2014, 12:34 PM   #85
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
This is what I was going to use as a secondary option #3,but the clarification is so vague!.
ID:	22998   Click image for larger version
Old 02-27-2014, 03:51 PM   #86
buzzinhalfdozen
Liked 11 Times in 8 Posts
Dan, I don't think it's the cost of the parts (though it may be in some cases) needed that has most scratching their heads. I believe it's the apparent vagueness of the wording and the revising that has most wondering...my self included. Heck less than 100 dollars and you're sweet, but again why put it on if the NHRA is just gonna rescind it or change it again. Merely my opinion. Joe
Joe Buchanan SS/BX 3117
Old 02-27-2014, 04:05 PM   #87
Jeff Teuton
Per NHRA. Three methods of retention. Collector welded to primary tubes; approved tether, or hanger attached to body and collector so it can't fly off. I think all the details have already been talked about. The third option (hanger) is the newest. I think it is worded badly, but they want something bolted or attached to the body so it can't be removed very easy. I think we all knew about the welding and the tethers. I think Dan is right; it's just not that big a deal and it's once only. I am the messenger only.
Old 03-01-2014, 09:18 AM   #88
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Old 03-01-2014, 09:27 AM   #89
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Got casters on the bottom?
Rich Taylor
I/SA - 321
Old 03-01-2014, 09:27 AM   #90
Randall Klein
Liked 316 Times in 67 Posts
Very funny, but, No.
Plumbers strap prohibited.
Of course you know that, but thanks for the chuckle, with the winter we are experiencing any laugh helps
