Old 03-06-2014, 09:55 PM   #1
Todd Boyer
Liked 6 Times in 5 Posts
Default 340 Mopar Stocker Fuel line size
What size fuel lines should be used in a 340 Dart Stocker? Talking line from cell to regulator, and regulator to carb. I have access to some 10-AN but I'm thinking it's a bit big. Would 8-AN be a better choice?
Thanks in advance !!
Old 03-06-2014, 11:19 PM   #2
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Default Re: 340 Mopar Stocker Fuel line size
I think -8 to the regulator and -6 to the carb is fine. Is it a dead head system?
Dave Turner
SS/GT #1153
Old 03-07-2014, 09:38 PM   #3
George Mirza
8 works for most of us. The AVS has a good size bowl, 8 should work fine, 10 would be ok, I don't think you'll see a performance difference. I can make you a #8 fitting for the AVS if you need one.
George
George Mirza is offline   Reply With Quote
Old 03-09-2014, 09:41 PM   #4
Todd Boyer
Dead-head system - as in no return line, Dave? It won't have a return line. Car may be run in Pure-Stock locally to start out, in which case I have to run a mechanical pump.
Old 03-09-2014, 09:44 PM   #5
Todd Boyer
George
I will likely take you up on that offer, George.
Thanks!
Old 03-09-2014, 10:15 PM   #6
Dave Turner
Correct, a return less system. Given the application, the -8 should be good, and by the sound of it, George has you covered.
Dave Turner
SS/GT #1153
Old 03-10-2014, 07:51 PM   #7
Todd Boyer
I'd say so, Dave. Thanks for the input !!
