Old 03-09-2014, 09:34 AM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default Compare these 2
I want to compare these 2:
305 Stocker Motors: 1. Has a Carb QJ 207 2. Has Fuel Inj. TPI set-up
Just let's say both have the same H.P.
Carb motor goes 112 mph TPI goes only 109 . WHY ???
Should the shift points be different on the TPI motor ??
If so, Higher or Lower than the Carb Motor ??
Should the Stall on the Converter be Different ? Higher or Lower ?
What other things can make the TPI get some MPH ??
60 foot times are very close to being the same too.
"Pistol" Pete Dutko
Old 03-09-2014, 09:43 AM   #2
James Perrone
Liked 1,829 Times in 427 Posts
Default Re: Compare these 2
U need a carburetor..lol
james perrone 1290 STK
Old 03-09-2014, 10:46 AM   #3
pbp1
Liked 27 Times in 6 Posts
CFM of a Q-jet vs CFM of a TPI throttle body.
pbp1 is offline   Reply With Quote
Old 03-09-2014, 10:50 AM   #4
Ed Wright
Ed Wright's Avatar
And those long, small intake tubes. Like really long header primaries. Those TPI engines don't run up high. Take some gear out of the TPI car and it will likely run quicker too. On my chassis dyno, I never saw one that wasn't done by about 5500 RPM.
Ed Wright 4156 SS/JA
Old 03-09-2014, 11:10 AM   #5
ken robinson
Liked 224 Times in 87 Posts
Pete , were are your shift rpms (5500 ?) , think about what Ed stated , get some primary addons to make those tubes longer . .If you already have tethers made you can always sale them .
Old 03-09-2014, 11:51 AM   #6
Signman
Liked 269 Times in 99 Posts
Pete
Two completely different animals.
Old 03-09-2014, 03:40 PM   #7
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
shift points on carb motor higher
488 gear in tpi set up, 513 in carb motor
5000/5200 converter in tpi motor, 5500 in carb set up, based on my 2 old camaros, they seemed to run prety well
jim powers is offline   Reply With Quote
Old 03-09-2014, 04:06 PM   #8
Joe DeMarzo
Liked 119 Times in 11 Posts
Thumbs up Re: Compare these 2
Pete, listen to JP both his Camaro's were very fast. Text me later to talk.
Joe DeMarzo 1317 STK
Old 03-10-2014, 08:43 AM   #9
pistol paul
have the chief put the supertune to it
pistol paul is offline   Reply With Quote
Old 03-10-2014, 05:56 PM   #10
Greg Hill
Liked 279 Times in 68 Posts
The manifold is not good on the F.I. Car.
Greg Hill 4171 STK
