Old 03-11-2014, 07:14 PM   #41
JWagner
Liked 17 Times in 4 Posts
Default Re: Metric 200 Trans
Mark,
Would there be a disadvantage to using a 200-4R transmission which has a much stronger case?
Jim
JWagner is offline   Reply With Quote
Old 03-11-2014, 09:48 PM   #42
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The 200-4R is about 50 lbs heavier, and the overdrive gearset would add some inertia. Overdrive is .67 ratio, which is a bit too much to race with, but can be switched out to a .72 ratio from a Strassburg built 4 speed version of a 180-C . There are some performance parts available, but the main one to get is a new Forward Clutch Drum assembly. The production one will snap off the spline on the input shaft. Aftermarket shafts have cured that problem.
Old 03-11-2014, 11:35 PM   #43
Liked 5,145 Times in 1,964 Posts
Because of what Russ mentioned, I assume, the 2004R seems to be at least a tenth slower than a 3 speed, even just using 1-2-3 in the quarter.
Old 03-12-2014, 09:46 PM   #44
Still have that Chevy core..
I DID find out I can ship it to Eastern Pa. via UPS, for $125
