#11 | |
Liked 30 Times in 17 Posts
I have an email indicating the large core cam is ok as long as you aren't using roller cam bearings. I will try to find it and post it if I can. Tracy Last edited by Pedigo Perf; 03-12-2014 at 10:26 PM. |
#12 |
Guest
Posts: n/a
I've never done it, but pontiac has problems with cam bearings. If you spin one and do excessive damage to the journal how would you repair it? They don't make an oversize cam bearing for my deal. I think the 50mm would be logical for a repair.
#13 |
Liked 327 Times in 121 Posts
A decent machinist could make a sleeve and the machining process would be similar to sleeving a cylinder.
#14 |
#15 |
Liked 606 Times in 213 Posts
Paul, you are assuming that you use a standard cam bearing and not a roller bearing, right? I believe that is the issue.
Gary Hansen - SS/FA 4911, B/SA 4911 |
#16 |
Liked 79 Times in 7 Posts
The first post was about "BIG BASE CIRCLE" cams. When someone has a minute could you please forward me a spread sheet w/ what the stock base circles are for everything amc,ford,chry.chevy,hudson (you never know) What if you have big power adder like a 4/7 swap cam? And it ends up being the same as a ford would something like that be considered as crossbreeding?How do you tell the car (driver) in say B stock auto that just got his 440,396,427 etc A#S drug down the track by a 2014 302 you have to go home because your base circle is to big.
#17 |
#18 |
I guess I don't really understand the issue here....What is the advantage to a large bearing cam shaft, as opposed to a standard bearing...????? I understand how a roller bearing camshaft bearing might make a half a horsepower.....plus add to the longevity of the engine. but a standard cam bearing versus a larger one??????? then why do Mopar guys use smaller rod bearings (chevy)...??? I'm just saying
#19 |
The issue here isn't the larger cam bearing, it's the larger base circle LOBE that the larger bearing register allows you to fit in.
#20 | |
Guest
Posts: n/a
Exactly!! Great post.
