Old 03-31-2014, 02:44 PM   #21
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Ordering New Transmission, but What Gears ?
40+ years ago on 7" slicks I learned that the steeper first gear Muncie transmission would only run fast when the traction was very, very good.
Even in a small block hydraulic cam rpm limited 3200lb car.
A 2.5 trans with a 4.88 rear gear and a steel flywheel dug holes in the starting line sometimes......
Basically we needed an aluminum flywheel at the minimum to adjust to the track conditions. Going from a 2.5 to a 2.20 first was a huge change and we threw that at the car in desperation at one race. A bog was faster than a spin........by a lot...We were racing on asphalt then and hot summer was way less traction than cooler conditions by a mile....Smoking the tires on the launch was normal....but only a little....
The fastest car in our class ran less gear in the trans and upped the TQ as much as possible with long collectors and other tricks....
Back in the traction limited days of 7" slicks...
Basically I think you have to pick something that is not as aggressive as you might like or think it could use. A happy medium so to speak.....
I don't miss those days one bit.....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 03-31-2014, 04:16 PM   #22
Adger Smith
Liked 880 Times in 311 Posts
Rich,
I think we walkd in the same shoes. I cut my teeth racing with a 69 Z-28 as a stocker. I raced it while I was in college. We carried 2.52 and 2.70 gear set trannys with us,as well as a 14 lb alum flywheel and a 34 lb Flywheel
I also had an alum hat with a Schiefer alum plate I had a lot of trouble with the heat shield. Back in the day it was fun, but today it would be hard work.
Adger Smith (Former SS)
Old 03-31-2014, 08:14 PM   #23
Rich Biebel
Yes we did Adger....
My race partner and I became friends with a man that had a '69 Z/28. It was nearly new but was a racecar running F/S at the time. He had fully prepped the car and it had a race engine I drove it a couple times.
I was convinced he should get that 2.20 first gear trans out and I installed a 2.5 first like we ran in our car.
I was used to the hydraulic cammed engine we ran....350/295
His 302 was nothing like the 350 and would spin the tach to the moon if it spun the tires which it did. Leaving at 6500-6800 and with not much traction at our local track.....well forget about it......LOL
I also learned that the 2.5 box would not shift anywhere near as good behind the 302 at the much higher rpm...
Broke some trans parts pretty quickly with it but man that car was great fun to get behind the wheel of....
Black with white panels on the hood and trunk....black and white houndstooth interior and the cold air hood with all the stuff to go with it....except he threw some of it away thinking it was no good for racing....
The car went 12.1's in F/S in 1969 or 1970
Rich Biebel
S/C 1479
Stock 147R
Old 03-31-2014, 08:52 PM   #24
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
I'm getting closer to settling on this. Thanks for ALL the "combinations".
Yes, it's more inclined to be a "torque engine", but it still does pull nice up at the big end.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 03-31-2014, 11:07 PM   #25
ss wannabee
Liked 7 Times in 7 Posts
Aubrey...did you ever try launching it at 5000 rpm?
ss wannabee is offline   Reply With Quote
Old 04-01-2014, 12:04 AM   #26
Aubrey N Bruneau
I did in Medicine Hat... but traction wasn't dependable. When it did hook, it bogged.
I don't go there any more.
Hoping for Mission in early June, but we're going on a big trip in May, for our daughter's wedding. That may stifle that particular race.
Old 04-01-2014, 01:18 AM   #27
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Ordering New Transmission, but What Gears ?
I hope you can pull it off, Aubrey. It would be great to see you and the car again at Mission. Its one of my "must do" trips every year at one of my favorite tracks. Take care.
Danny Durham
Old 04-01-2014, 11:00 AM   #28
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Aubrey, I would not be afraid of the 3.19 first gear. The super light clutch-flywheel assembly will allow you to accelerate the car without wheelspin. I would go with a 2.00 second and 1.40 third with the 3.19. The faster you can accelerate the car in the first half of the track, the lower the ET. Race setups have you in high gear at the eighth mark and it's just the ride from that point on regardless.
Old 04-01-2014, 08:32 PM   #29
Pvt Parts
Pvt Parts's Avatar
Yep...
Old 04-01-2014, 08:57 PM   #30
Todd Hoven
Guest
Posts: n/a
Yep...
X2.
